Hi all,
I'm going to be selling my R32 GT-R early next year (Feb/Mar) in order to fund a house. I'm putting it up for sale now so I can hopefully have a buyer ready when I've completed some final work on it. The car is located in Perth but I'm willing to ship interstsate. Specs are listed below.
1992 R32 GT-R, 130,000kms on chassis, 6,000 on engine. 530 kW/710 hp @ 25psi on United E85.
Price: $52,000 O.N.O (no swaps please) - I can also arrange for registration for any NSW buyers interested.
Engine:
- R34 GTR bottom end, completely stripped
- Block acid dipped, cleaned, bored & honed
- R34 GTR crank (30,000 km) and rotating assembly balanced
- ACL Race bearings
- ARP main studs
- ARP head studs
- Nitto oil pump
- Ross forged pistons
- N1 water pump
- Ross 1000hp harmonic balancer
- Tomei cam gears in/ex
- Tomei Poncam 260 deg 9.15 lift in/ex
- R34 GTR head (30,000 km), refreshed with:
    - New valve stem seals
    - Bronze valve guides
    - Brian Crower dual springs
    - Brian Crower titanium retainers
- Tomei metal head gasket (1.3mm)
- Tomei oil pan baffle kit
- Autech catch can
- ARC grille oil cooler
- HKS fuel rail
- Splitfire coilpacks
- 6x Bosch 2200cc injectors
- AN-8 Teflon braided fuel line from external pump to rail
- Holley Dominator 1800 external fuel pump
- Walbro 460lph in tank fuel pump
- 3L surge tank
- Turbosmart FPR1200 fuel pressure regulator
- Koyorad radiator
- Nismo low temp thermostat
- TRUST 100mm drag intercooler
- 6boost T4 twinscroll exhaust manifold
- Precision 6870 Gen 2 turbo (1.00 twin scroll, v-band rear housing)
- Turbosmart Powergate 60mm
- Custom fab work for all intercooler piping (stainless steel), intake piping (K&N pod)
- Custom fab 4" dump pipe into 4" stainless steel exhaust (2x Magnaflow oval mufflers)
- Adaptronic ECU
- GReddy Profec OLED boost controller
Suspension/Brakes/Wheels:
- TEIN Super Street coilovers (5000km old)
- R34 GTR Brembos front & rear
- Project Mu 330mm front & rear
- Project Mu brake pads front & rear
- 18 x 9 +20 BBS LM wrapped in 6000km old Yokohama ADVAN AD08R tyres (265/35/18)
- HICAS locking bar
Driveline:
- Rebuilt R32 GTR standard gearbox (refreshed with OEM Nissan parts 6000km ago)
- Exedy twin plate clutch
Interior, Exterior & Accessories
- R33 GTR seats in front (older pic attached shows R34 seats, but they have been switched out for R33 ones)
- Nismo 320kph speedo from factory
- Momo steering wheel
- N1 headlights
- Genuine N1 3 piece sideskirts & rear spats
- Genuine N1 front bumper
- Full professional MNP1 respray.
- HKS Kansai Service strut tower bar (not pictured, but included)
- Rockford Fosgate speaker system front + back with Alpine single DIN head unit
As previously mentioned, I'm preparing some final modifications and work prior to sale, which includes:
- Fitting of a DEFI ZD OLED display as a readout for oil/water temp & pressure
- Fitting of a Platinum Racing Products R35 GTR coilpack kit
- Re-tune on 35 PSI boost (the car was previously running this boost with a precision 6466 Gen 2, making the same power as it does now with the 6870 on only 25 PSI)
- General clean up of body/full detail
- Addressing minor things like cosmetic wear (fading) on weatherstrips (seals and trims are generally in great condition)
The car is accident and rust free. I have some receipts for parts and work carried out on the car. The car does not have aircon installed, but I have the entire system, including the lines in perfect cosmetic and functional condition, which will be included in the sale.
Most maintenance has been carried out by myself (3000km intervals), using Penrite 10 tenths racing oil (10W-40). Redline shockproof oil in the gearbox.
You can contact me on:
Mobile: 0411 271 646 (prefer text, but can arrange calls after work hours)
Or PM me through here.
Cheers,
Nav
16107199_10154301860437358_7453806377926729462_o.jpg.f5e3e435f3ddb610c66124fd8300a575.jpg
PPSR Search Certificate 6885549857410001.pdf
https://www.sau.com.au/forums/topic/472839-700-hp-mnp-bnr32-1992/
    • The old manifold was quite under the GTR strut brace.  The new manifold is quite [unknown] the GTR strut brace. The GTR strut brace was needed to clear the bonnet vents. The Old strut brace will almost certainly clear the new manifold, but not the bonnet vents. The old strut brace will almost certainly clear the new manifold, and the new bonnet without vents. But I am hoping the GTR strut brace clears the new manifold :p
    • On the bright side, at least you knew that it happened and remedied before anything happened. A friend of mine just took his Fiat 124 to a shop for an oil change and they didn't tighten the oil filter housing properly. 4.5 quarts spewed out and even after refilling + tightening the cap the engine has a tick now.
    • So, more pain. The FAST manifold is a little larger than the stocker. This is problematic because there really wasn't much clearance to begin with, so going from 'barely enough' well into 'no' is sad based on the external dimensions of the thing, even though where it bolts to the head is the same. Result is the fuel rails sit a good 25mm higher, and this is a bit of an issue with the wiring that runs behind the motor, and the fuel lines, and everything else. When pushing the manifold on, it required a huge amount of force to crush wiring looms to fit it, sensors like the MAP sensor are about 1mm from the firewall, and the FPR just has to bend ABS lines to be forced into place. After some brainstorming and some sad drinking, the loom for some reason ran from the grommet behind the ABS sensor, then to the driver side head, then back to the passenger side head. So all of this was pulled back and stripped, a few wires cut and rejoined, so that the 'branch' was now on the passenger side's head as below: Before you basically couldn't see anything behind the driver head. This is much improved! The MAP sensor is now pointing up (instead of at the firewall) Brackets have been made up for the rail. The rails are for a LS1, the manifold is designed around a LS2 as it's base. Which of course has slightly different bracketry and water pump clearance, hence the mods people need to do. Should be hopefully mounted tonight. I spent money on a new FPR that is slightly more compact than my Turbosmart FPR1200. The gauge has also been moved to the rail. There's also apparently an ORB to AN Union instead of the adapter, because the ~25mm of the current adapter is going to make the difference. Provided this all goes together and arrives today, it'll be the totally not stressful attempt to start it.
    • This seems like a pointless exercise. There is no E30 availability. Ongoing availability of E85 should not be assumed. Flex-fuel is the only sensible approach, so you can use E85 when and where you can get it, 98 when that's al you can get, and anything in between as you fill it up and drain it down. And if that means replacing the pumps, fitting a flex capable sensor/ECU/whatever has to be done to these Renault shitboxen, then.....so be it?
