Quick question guys. I have a 92 GTS-T and I will be installing the JapSpeed bellmouth downpipe. I have access to a lift. Can I do this job completely under the car? Or will I at least need to undo the heat shield from overhead before moving to working under the car? I can see all 6 elbow bolts by the turbo from underneath the car, so I feel like I can do the install without having to remove the heat shield. Thanks!
https://www.sau.com.au/forums/topic/472844-downpipe-question/
It would be hard to do from underneath. The top 2 downpipe bolts also secure the heat shield bracket, so would probably be hard to get back in from below.
You'll probably want to confirm that the wastegate flap doesn't catch on the dump pipe, which means you have to remove the actuator arm circlip. This will need the heatshield off anyway.
So even if I worked completely from the bottom and undid the 6 elbow bolts and undid the 2 bottom downpipe bolts to remove the assembly like that, it wouldn't work? Sorry if this is a rookie question. It took 3 hours just to remove the rusted cat and replace it with a decat last week, so I'm trying to make this downpipe install as smooth as possible aha.
I had mine off the other day, so the process is fresh in my mind. I think it would be harder, and take longer, to do it all from underneath, but it is probably doable (is that a real word?). If you want to check that the wastegate flap doesn't foul on the new dump pipe, you'll have to take the heat shield off anyway.
Why would you have to do it all from underneath? Are you going to make the car get up so high and not be able to reach for the whole job?
I can understand wanting to do it all from the top if for some reason you had no jack or lived on the side of a hill
  • Like 1
    • Throwing my spoon to the soup here a bit.  When I installed a 044 back in 2012, along with the direct power mod, the car became very difficult to start. To a point I burned one starter motor as I was late for work and tried to get the thing going. With some tuning and careful use of gas pedal when cranking it became bearable. Trying to make this short as possible, but the 044 died after 2-3 years, after which I went with an AEM 320lph pump, which also died after about 4 years to my dismay. After that I went with a Nismo pump, and while trying diagnose an emissions problem, I noticed for the first time that my fuel pressure was 5bar/72psi on idle, and that removing the vacuum line did nothing. After monitoring the situation, and removing the direct power feed and going back to FPCM in attempts to remedy it, I noticed there was fuel in the pressure regulator vac line. Kept the FPCM, installed AEM external regu and the car became sooo much better in every way, including starting. And I had driven it like it was for 11 years.. Anyway, I agree these are likely two different problems, and the FP problem you just haven't noticed before. I do not know much about haltecs, but what first came to mind was the CAS, which probably is not there any more. So how is the wiring from haltec to gauge cluster? How is the battery voltage and alternator?
    • Your car was auto before? You have different diff ratio (auto vs manual i think? or n/a and turbo?)
    • +1 for getting a screen off alibaba, CarPlay/Android Auto is vastly better than whatever navigation cars had 10 years ago. I got an Android screen for my 2015 BMW, huge difference. Fully compatible with factory stuff including iDrive controls.
    • Yeah, my offer was more to show exactly how rough and ready the rig can be and still be useful. Youtube vids will definitely show cleaner setups. Same concept though.
    • I would guess the seal has gone down at the speedo drive and gearbox oil has crept up the drive cable sheath and fouled the speedo head.
