Hi All.
I have tried searching and found huge amount of information, however looking for advice to narrow down my selection.
Starting out with a completely stock GTR R33, would like a well rounded package targeting 450hp at the wheels on pump 98 fuel. Appreciate any advice on bolt on twin turbo upgrade selection and any other supporting mods needed. Car is a street car, do not want to move to far away from the standard drive ability.
thanks in advance
https://www.sau.com.au/forums/topic/472851-r33-gtr-upgrade-advice-needed/
In before everyone says do single turbo.
Because seriously, do single turbo if you want to get that sort of power and maintain street driveability.
If you really, truly must maintain twins:
-9s
HPI dumps
plazmaman cooler
good injectors
good aftermarket ECU
headstuds/gaskets
This might just make your desired power on 98, might also not but they're smaller turbos so shouldn't hurt your driveability much. Would suggest you go for a ride in a car with -5's on 98 and determine if that meets your driveability criteria before considering that size turbo
20 minutes ago, MrSquigle said:
Thanks for the reply's
not wanting to change the car to much, happy to leave it twin and standard looking. Are the Garrett GT2860r a decent upgrade from standard?
Flick through this. Your question has been answered 11ty times.
1 hour ago, r32-25t said:
it’s beleived then -9 will make fractionally more power but they both respond the same
Speaking from actual experience. Changing from R34 N1's (-7) to GTSS (-9) there was a re-markedly big improvement in response.
The -9's were on sooner, harder and stayed on the boil for alot longer
  • Like 1
Were the -7s stuffed? Cause I’ve driven both and couldn’t tell the difference
-7’s were perfectly fine. I was pleasantly surprised when I got the car back.
There are plenty of dyno read outs in the 26 thread and a lot of the 7’s get 20 psi closer to 4400rpm which is about what I was getting.
9’s were on 20 psi a good 500 rpm sooner .
-7s nosed over to 19psi by 7500 rpm.
9’s stay 21-22 psi all the way to 8000rpm
Same motor, exhaust, ecu etc
If you want to do it on the cheap with minimal mods you can buy all second hand bits for a basic -9 upgrade but you will need to run reasonable boost to get to 450rwhp on 98. Other options are mild cams, say basic 260 tomei, but everyone complains about the drive ability afterwards as they have soft ramp rates or E85, which will get you there with less boost and lower EGTs. Fuel economy will suffer though, but you can always run a flex setup if it's a daily and run 98 for commuting and E85 for an extra 20kw for track days or whatever.
You could also do a basic single conversion, not a kebab spec full twin scroll EFR setup, but just a basic new gen Garrett on a reasonable manifold, single gate.
If you want to stick with twins, I'd recommend -9s. -5s are too laggy for the street without a few accompanying mods, -7s run out of puff too early. My 2 cents :)
If I had a GT-R and didn't want to spend stupid amounts of money to make it fast, I would do all the handling, suspension, braking, cooling mods first.
Then go thrash the living daylights out of it on the track.
Once I am ready, would drop in ARP headstuds, higher lift cams, and a big sexy single.
    • FWIW a lot of the local owners that do a big build tend to have cars that are perpetually broken.
    • I just got this system but haven’t installed yet I got a Moroso sealed box (defect reasons) which will be set up same as their pic The quality is high grade, the correspondence I had with the owner (former head designer for Rockford Fosgate) was unbelievable, guiding me with what I needed. Even told me not to buy some things as it could be sorted in a different way at his loss. Just a bit of a bite with the exchange rate and don’t purchase gear in 1 hit that goes over $1,000 au, lol I forgot!
    • Thanks mate for that reply. Very helpful.    it’s a 2022 400R so would most likely lose those features as you say.     I did a quick compare of a rv37 nav and heading for sale in Japan to q50 model. I’ll pop pics below. Seems  Japan spec head into top, nav unit second below it   below pic Q50 aud delivered     differences seem to be Aus delivered has a different plug top left hand side of head unit- not sure what and where it goes.   and nav unit Japanese tv37 had an extra plug put    Again I’m really not sure what each of these differences mean!       the actual plugs on a v37 and q50 screens look identical on both screens… pics below for comparing. (One screen was is a us delivered one) but should be same gps signals etc as Australia.    If it were as simple as swapping a nav unit from q50 aud delivered im interested -just want to figure out what the missing plug is for before spending big $ on a second hand part for it to not work, and I guess with the head unit, if the band expander does the job (I got a 20mHz so should get the range I’m after) so should narrow my issue down to nav unit only.  I’d love to know what the extra cable on rv37 does and if I eliminate that part what it’ll do to the setup,    and also, if I can figure out what that head unit plug difference is, what does that cable do and where does it got can it be altered or re-plugged?! Excuse my ignorance what is ACP/AA, what does that stand for? (Apple car play? Android air play)? so If I swapped head units to save using a band expander, I’d likely lose those better features to have an oem Unit operational. Better to use a band expander and retain AirPlay options and newer version of head unit     provably best to band expand it, and focus on the nav unit. th isn’t  a big deal/ would be cool to have it working  from what I can tel we use a PAL Signal and Japan uses a NTSC signal  I don’t know if there’s a co better or if the screen only reads NTSC, or if it’s the tv module that needs replacing… no big deal don’t need it but more of a curiosity thing on that!   Thanks for the info re tyre sensors, helpful and great to know.  I was reading the online manual off Japan website and it seemed to make it sound more confusing than it is  I guess a rim replacement would require the sensors to be moved to a new rim to carry that option over?!     Thanks for the info regarding diagnostic mode. I appreciate your help mate. Trying to brainstorm here to find a solution to get as much gadgets as I can working! I plan to get my local Nissan tech to have a look too who used to be at an Infiniti dealer back in the day to see if any thing they have or idea can find a soliton. But hoping anyone here has gone down the same route to make life easier!!   i guess identifying the cable/plug differences and what they do would be a great way of finding out if the units are transferable    thanks again
    • No idea about the remote start part. If the V37 nav is anything like other Nissan JDM vehicles, you can't get the factory Japanese nav working in australia, a card from a different car almost certainly won't work, those cards are usually matched to the serial number of the DCU.  You could be possibly swap out the components from a AuDM Q50 to get it working, but if this is a new model (2021+) 400R, then you will lose the newer features like ACP/AA.  That said, if you have ACP/AA, just use google maps.. I assume a band expander would be required to get the local radio stations, but don't forget the Japanese FM band is narrower than ours, so you still might not be able to receive all Australian stations. I can't see any reason the tyre pressure sensors won't work here, there is the sensor unit inside the rim and the receiver nearby in the wheel well.  I have never had to change the batteries on my 2015 Q50, so I assume they last quite a while.  A straight battery change shouldn't need them to be re-registered as they are the same unit, that should only be required if you replace a sensor with a new one.   Word of warning, if you ever go into the 'secret' diagnostics mode on the main screen, DO NOT EVER do a 'reset' in this menu, it will erase all of your model specific data in the DCU and you will need a trip to a dealer to re-program it all, which would be particularly painful being an import.  This applies to the AuDM Q50 too.
    • There is a known issue with the mix door motor on the Q50 which causes these symptoms, not sure if it is common on the Y51 though.
