Yo!
so yesterday my s2 R33 rb25det was working perfect never had an issue. i get in my car i go for a drive i go to hit boost and its struggling, it sounds like i have a bee r limiter but no power at all just making mad pops from the exhaust. the factory boost gauge shows its working but yeah no power and it struggles real bad.
i have checked all the piping and lines. no leaks or splits.
if anyone has gone through this or knows how to fix it please help. i just wannnaaaaa hit boost :(
https://www.sau.com.au/forums/topic/472876-r33-misfiring-trying-to-hit-boost/
stock ecu. 11.5psi. s2 r33 turbo. there is a paper in the car that its been tuned to 11.5psi. but doesnt feel like it. i changed the spark plugs seems to be working a little more better now. just gonna scope out for leaks with air compressor. i was hoping nothing shorted when i was using a light test and accidentally hit the smoke lighter and it sparked
hasnt been tuned for a few years. i have a dump and highflow cat and looked inside it no cermaic wheel bits. ive just put gasket maker for bov. tighten up everything else and install a boost a gauge tomorrow and see whats going on from there. its stopped misfiring. boosting better now. but feel like its lacking 10% of power i reckon but i'll let gasket dry over night and see how she goes in the morn.
Turn down the boost, your car isn't tuned.
You cannot tune the stock R33 ECU unless it has been remapped by Toshi or by those off the shelf remapped Nap ECUs (totally useless with Australia fuel and climate).
update* seems to be running better now. it ind of slacks but its getting there.
also i noticed after putting gasket maker for bov. when cold it kinds of flutters a little and makes a weird little metal noise after dose for under a sec. but once its warmed up it goes back to whoosh sound and no metal noise :/
strange. now its starting to do it again.
so when i put my foot down as it gets around 4-5k mark it looses power even with my foot on the floor it doesnt wanna go anywhere. i try it again and boost will come on i try it again it wont want to move... so confused
Edited by AndreW_R32
    • Sadly I can confirm if you are actually seeking to drift, you will quite easily spin up one wheel. Even if you're going in a straight line. I am not entirely sure of the metrics/terminology here but there's only a certain amount that the helical will actually spin both wheels. I've seen it on video with my own car where two lines of smoke switch over to just one after you really get in to it. Unlike with a clutch diff where you can keep your foot planted until the car regains grip, in my experience with the helical you want to be utilizing traction control allowing LIMITED slip or lifting (partially) when you start to spin up both tyres with a Nissan helical. Which makes them pretty sub optimal for drifting duty. That said... this is probably a helical on numbers alone. Just put the Kazz in
    • Let's just fix the problem by f**king the rest of the gearbox.
    • Unlikely, as per Greg's post. This is not helical diff behaviour unless one wheel is up off the ground. Shimming what? You don't "shim" a mechanical LSD. Probably not in the sense that you have heard of people "shimming" a diff. And the process that Nissan f**kwits call "shimming" a diff involves super-preloading a VLSD cartridge against the side of the diff to create a friction/wear point (in a place that it wasn't supposed to have one) to make the sloppy, useless, viscous diff into a hybrid viscous/mech abortion. In case it isn't clear, I consider the process to be stupid. Nike.
    • How much does the shifter move when the car is in gear with the engine off? If it is more than about 1cm you need to replace your shifter bush. Your shifts will just get crunchier, not faster, with a short shifter unless you also rebuild the whole box
    • I should video mine, will prob do it tomorrow    Between 1st and 3rd, you could fit another two gears. That is how loose and wobbly it is   horrible:(
