AndreW_R32 Posted December 8, 2017 Share Posted December 8, 2017 Yo! so yesterday my s2 R33 rb25det was working perfect never had an issue. i get in my car i go for a drive i go to hit boost and its struggling, it sounds like i have a bee r limiter but no power at all just making mad pops from the exhaust. the factory boost gauge shows its working but yeah no power and it struggles real bad. i have checked all the piping and lines. no leaks or splits. if anyone has gone through this or knows how to fix it please help. i just wannnaaaaa hit boost Link to comment https://www.sau.com.au/forums/topic/472876-r33-misfiring-trying-to-hit-boost/ Share on other sites More sharing options...
GTSBoy Posted December 8, 2017 Share Posted December 8, 2017 Spark or fuel. One will be not working right. Search. Link to comment https://www.sau.com.au/forums/topic/472876-r33-misfiring-trying-to-hit-boost/#findComment-7861746 Share on other sites More sharing options...
AndreW_R32 Posted December 8, 2017 Author Share Posted December 8, 2017 idles fine, drives fine. just cant hit boost Link to comment https://www.sau.com.au/forums/topic/472876-r33-misfiring-trying-to-hit-boost/#findComment-7861747 Share on other sites More sharing options...
AndreW_R32 Posted December 8, 2017 Author Share Posted December 8, 2017 ill sus out sparks and fuel filter(old) and fuel pump Link to comment https://www.sau.com.au/forums/topic/472876-r33-misfiring-trying-to-hit-boost/#findComment-7861748 Share on other sites More sharing options...
AndreW_R32 Posted December 9, 2017 Author Share Posted December 9, 2017 update* i changed fuel filter. no more misfiring but still lags power. cant feel pressure when boost is on like its n/a Link to comment https://www.sau.com.au/forums/topic/472876-r33-misfiring-trying-to-hit-boost/#findComment-7861755 Share on other sites More sharing options...
Ben C34 Posted December 9, 2017 Share Posted December 9, 2017 They are pretty slow standard. Link to comment https://www.sau.com.au/forums/topic/472876-r33-misfiring-trying-to-hit-boost/#findComment-7861757 Share on other sites More sharing options...
AndreW_R32 Posted December 9, 2017 Author Share Posted December 9, 2017 its at 200kw and feels like 100. i just wanna figure it out before i do the g3 hypergear turbo setup. Link to comment https://www.sau.com.au/forums/topic/472876-r33-misfiring-trying-to-hit-boost/#findComment-7861758 Share on other sites More sharing options...
GTSBoy Posted December 9, 2017 Share Posted December 9, 2017 Drop the exhaust. Look in the cat for the turbine. Then douse it in petrol and throw a match on it. 1 Link to comment https://www.sau.com.au/forums/topic/472876-r33-misfiring-trying-to-hit-boost/#findComment-7861770 Share on other sites More sharing options...
AndreW_R32 Posted December 9, 2017 Author Share Posted December 9, 2017 possible that the issue could be that the turbine has broken apart? Link to comment https://www.sau.com.au/forums/topic/472876-r33-misfiring-trying-to-hit-boost/#findComment-7861792 Share on other sites More sharing options...
Super Drager Posted December 9, 2017 Share Posted December 9, 2017 Check your coilpacks? 1 Link to comment https://www.sau.com.au/forums/topic/472876-r33-misfiring-trying-to-hit-boost/#findComment-7861796 Share on other sites More sharing options...
AndreW_R32 Posted December 9, 2017 Author Share Posted December 9, 2017 ill give em a check tomorrow. took it for a test drive and the turbo was glowing red hot af Link to comment https://www.sau.com.au/forums/topic/472876-r33-misfiring-trying-to-hit-boost/#findComment-7861798 Share on other sites More sharing options...
niZmO_Man Posted December 10, 2017 Share Posted December 10, 2017 What ECU? What boost pressure? What turbo? Probably broken turbine. 1 Link to comment https://www.sau.com.au/forums/topic/472876-r33-misfiring-trying-to-hit-boost/#findComment-7861905 Share on other sites More sharing options...
AndreW_R32 Posted December 11, 2017 Author Share Posted December 11, 2017 stock ecu. 11.5psi. s2 r33 turbo. there is a paper in the car that its been tuned to 11.5psi. but doesnt feel like it. i changed the spark plugs seems to be working a little more better now. just gonna scope out for leaks with air compressor. i was hoping nothing shorted when i was using a light test and accidentally hit the smoke lighter and it sparked Link to comment https://www.sau.com.au/forums/topic/472876-r33-misfiring-trying-to-hit-boost/#findComment-7861917 Share on other sites More sharing options...
niZmO_Man Posted December 11, 2017 Share Posted December 11, 2017 Stock ECU tuned? Eh? Turn the boost down to 7 psi. Wait, does it actually boost? Did you drop the cat? Link to comment https://www.sau.com.au/forums/topic/472876-r33-misfiring-trying-to-hit-boost/#findComment-7861954 Share on other sites More sharing options...
AndreW_R32 Posted December 11, 2017 Author Share Posted December 11, 2017 hasnt been tuned for a few years. i have a dump and highflow cat and looked inside it no cermaic wheel bits. ive just put gasket maker for bov. tighten up everything else and install a boost a gauge tomorrow and see whats going on from there. its stopped misfiring. boosting better now. but feel like its lacking 10% of power i reckon but i'll let gasket dry over night and see how she goes in the morn. Link to comment https://www.sau.com.au/forums/topic/472876-r33-misfiring-trying-to-hit-boost/#findComment-7862034 Share on other sites More sharing options...
Dose Pipe Sutututu Posted December 11, 2017 Share Posted December 11, 2017 Turn down the boost, your car isn't tuned. You cannot tune the stock R33 ECU unless it has been remapped by Toshi or by those off the shelf remapped Nap ECUs (totally useless with Australia fuel and climate). Link to comment https://www.sau.com.au/forums/topic/472876-r33-misfiring-trying-to-hit-boost/#findComment-7862064 Share on other sites More sharing options...
niZmO_Man Posted December 11, 2017 Share Posted December 11, 2017 16 hours ago, niZmO_Man said: Turn the boost down to 7 psi. Link to comment https://www.sau.com.au/forums/topic/472876-r33-misfiring-trying-to-hit-boost/#findComment-7862067 Share on other sites More sharing options...
AndreW_R32 Posted December 12, 2017 Author Share Posted December 12, 2017 update* seems to be running better now. it ind of slacks but its getting there. also i noticed after putting gasket maker for bov. when cold it kinds of flutters a little and makes a weird little metal noise after dose for under a sec. but once its warmed up it goes back to whoosh sound and no metal noise Link to comment https://www.sau.com.au/forums/topic/472876-r33-misfiring-trying-to-hit-boost/#findComment-7862142 Share on other sites More sharing options...
AndreW_R32 Posted December 14, 2017 Author Share Posted December 14, 2017 (edited) strange. now its starting to do it again. so when i put my foot down as it gets around 4-5k mark it looses power even with my foot on the floor it doesnt wanna go anywhere. i try it again and boost will come on i try it again it wont want to move... so confused Edited December 14, 2017 by AndreW_R32 Link to comment https://www.sau.com.au/forums/topic/472876-r33-misfiring-trying-to-hit-boost/#findComment-7862404 Share on other sites More sharing options...
89CAL Posted December 14, 2017 Share Posted December 14, 2017 Did you turn the boost down as suggested? Link to comment https://www.sau.com.au/forums/topic/472876-r33-misfiring-trying-to-hit-boost/#findComment-7862452 Share on other sites More sharing options...
