Hello all,
Because most of the people ignore long posts I'll try to make it as short as possible.
I'm Kevin from Belgium, all my life I've been passionate about Japanese cars.
This is my first car, the most things I learned about cars is with this car. I swapped it myself from a 4A-FE to a 4AGE 20V
https://www.facebook.com/Toyota20vSwap/
10 years I went for the first time to JAE in the UK and saw a lot of JDM cars that I have never seen before (because Belgium is LHD)
I saw a white R33 and it was love on first sight (even tough I was a Toyota enthousiast). Years laters I bought my own white GTST with the 40th Anniversary bodykit, exactly like I wanted it (except the f*cked up front bumper)
Unfortunately the previous owner maintained it badly and "upgraded" it with bad parts.
Unichip piggybag,cheapass IC installed badly and saw pieces out of the bumper, Greddy boostcontroller with turbopressure that went all over the place.
First time I drove it the little tube on the cam covers came of.
Not a big problem, I fixed it. Besides that I had the turbo pressure problem so I removed the Unichip and boostcontroller to make as stock as possible. I drove a little bit on wastegate pressure and it drove ok.
I only drove it a month and then it went in wintersleep. I bought a house that needed some work so I stayed in hibernate for 2 years.
I get it back out, refresh oil and wanted to set it to 0.7bar with a manual boostcontroller.
After some pulls the engine went bang, I think I drove it for 1000miles since I bought it.
Put it angry back in the garage until a friend took the initiative to help me to remove the engine.
5a2ed07c2f869_IMG_20170929_164558(Medium).thumb.jpg.3fc2772b835221bfb6a91d37052f0653.jpg
I took the opportunity to clean the engine bay.
They removed the inner board of the wheel arches for the IC pipe so everything was very dirty.
5a2ed11e8996e_2017-10-3120_59.03(Large).thumb.jpg.356881e904515645dce321e1d519cfc9.jpg
I'm almost half way :-)
I also started to disassemble the engine. Long story short: Pistons broke:
oil pump:
This week everything will be cleaned and measured.
What certain needs to be replaced:
- Turbo (still original)
- Exhaust manifold (cracked)
- Pistons obviously :D
- clutch (cheap ass worn in 6-pad)
Goal: +-400bhp but most importand fast spool, torque and fun to drive. I'm not a dyno figure kind of guy.
ATM I'm thinking about a "oem" like exhaust manifold with a GTX37xx turbo. But all imput is appriciated!
Thanks!
  • Like 2
https://www.sau.com.au/forums/topic/472898-frekev-r33-gtst-from-belgium/
  • 4 weeks later...
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
