Hey guys.
Thought I'd pop up a thread for my 33 sedan.
Had a few cefiro's in the past (build thread in cefiro section), basically street driven drift cars.
We bought this to use as a daily. It was pretty much dead stock, turbo auto, apart from a dump pipe and 3 inch cat. Daily'd it for 3 years trouble free.
Was getting a bit tired of the cefiro (maybe getting old? haha), no air con, wheels too big, too loud, etc. That and the lack of drift days in NSW, led me to sell. So sold that with the intention of getting a R34 sedan.
Drove a couple and realised they were not that much better than the 33 I already had, and in worse condition to boot.
So, enter the R33 build (its really just buying bolt on parts, why I love nissans, haha)
Plan is a nice streeter, with occasional track (grip/drift) work. Air con, and comfort being reasonably important, (showing my age!)
What I started with
First mods were fitting my nardi. Used a works bell boss kit, good bit of gear.
Drivers seat was fairly flogged out, so replaced it with a S15 seat, with the rails modded to sit lower, and pick up the  4th bolt hole.
Had S15 seats in the cefiro, and find the driving position suits me well, being a bit on the bigger side.
Still chasing a passenger seat to match.
Picked up a fujisubo cat back. I wanted this car to be quieter than the cefiro, and have a proper rear muffler (no cannon)
I had to fit a silencer (bunch of rags+ tape) to leave the house without waking the entire street up in the cef. Was dumb.
Exhaust was from a coupe I assume, so had to lengthen it 90mm, and tweak the angle of the pipe to get it to tuck a bit better.
Turned out ok, and had the look I was after
It looks angled down in the photo, but I assure it sits level :)
Bought some coil overs, BC racing. I had these in the cefiro, did 90k on them (on some shit roads of NSW south coast) and never had a problem. Fitted them along with some rear camber arms.
Also fitted my cusco 2 way center to the stock 4.3 diff, retaining ABS,
 No pics of the install of these, but fairly straight forward.
Went with R34 gtr wheels. I wanted wheels inside the guards, and able to run a decent size tire. Currently have a 265/35/18 all round, and they basically don't scrub, when these tires are done, might drop to a 255, or 245 front
Few other cosmetic changes, rear wing delete (would love a impul wing) and probably the thing I'd wanted to do the most, fit coupe headlights.
These were not a straight fit, had to trim the rad support, and wiring had to be modified to suit the twin globe. But, love the way it changes the look.
So things still to do:
Fine tune heights/wheel alignment
Carry out manual conversion. Have all the parts needed, picked up a box that needed a second gear syncro, so will do that before it goes in.
Hopefully get the conversion done over my christmas break.
Cosmetically will get the front bar repaired/painted, and would like to pick up some factory side skirts, although they seem to be pretty rare.
Overall, so far, very happy how the car drives, lightyears  ahead of my old cefiro chassis wise.
Once its manual I'll work out what the plan power wise will be, (probably a hypergear bolton turbo, +associated mods)
Cheers
Edited by CEF33Y
Duplicate pic
  • Like 3
https://www.sau.com.au/forums/topic/472900-r33-sedan/
    • This is the clearest explanation out of those: Page 77: Turn the crankshaft clockwise two full rotations with the tensioner pulley installation bolt in a loose condition. Insert a wrench into the tensioner pulley hexagonal hole to fix the tensioner pulley in place, then tighten the installation bolts. Tightening torque: 43–58 N·m (4.4–5.9 kg·m). The timing belt tension should be at the correct tension. Basically you turn the engine with the tensioner bolt loose, then use the allen key to hold it while you torque it up. And yes after that a good guide is being able to twist it 90o in one of the long free lengths of the belt
    • good choice....I have a set of those and use them all the time including on this job. Plus, no-one wants a damaged nipple
    • Thanks all, went with nismo strengthened belt and all genuine nissan idler and tensioner Question on RB25DET Neo Timing Tensioner: I have a question about the RB25DET Neo timing tensioner. In one of the videos (minute 20 of https://www.youtube.com/watch?v=17y37BB9xnA and minute 27 of https://www.youtube.com/watch?v=Pb99s2E9xUg), the process suggests tightening the tensioner pulley installation bolt to the specified torque initially, and then loosening it slightly to allow the spring to set the correct tension. Is this the correct approach? The R33 workshop manual on page 74 states: Loosen the tension pulley installation nuts. Insert the wrench into the tensioner pulley hexagonal hole and turn it clockwise to tighten the installation nut temporarily. The way this is written is confusing. Does this mean: Undo the nut, then reduce the tension by turning clockwise? Snug the nut so it stays in position without applying tension to the belt while removing the timing belt? The manual wording makes it sound like the nut will tighten automatically when you turn the tensioner clockwise , which is unclear to me.   Timing Belt Tension Adjustment Process: After loosening the tensioner nut, you turn the engine two full rotations by hand, which should set the correct tension. Once the tension is set, you tighten the bolt to 43 N·m (4.4 kg·m). Before tightening, you need to insert the Allen key into the hexagonal hole to hold the pulley in place while tightening the bolt. In one of the videos, it’s mentioned that you should twist the belt side to side, or turn it slightly to check if the tension is correct. The belt should turn halfway, indicating the right tension. However, I know that twisting or turning the belt is not a good idea. What are your thoughts on this? Finally, how can I ensure the belt isn’t overtightened? I’ve seen many cases where people have overtightened the timing belt.   Manual Excerpts: Page 74: Loosen the tension pulley installation nuts. Insert the wrench into the tensioner pulley hexagonal hole and turn it clockwise to tighten the installation nut temporarily. Remove the timing belt from each pulley. Page 77: Turn the crankshaft clockwise two full rotations with the tensioner pulley installation bolt in a loose condition. Insert a wrench into the tensioner pulley hexagonal hole to fix the tensioner pulley in place, then tighten the installation bolts. Tightening torque: 43–58 N·m (4.4–5.9 kg·m). The timing belt tension should be at the correct tension.
    • Takes a few minutes to malke one. Wood, or steel, or a wrap strap with some strategically placed solids to provide teh drive onto the ribs.
    • I would strongly suggest using the correct tool. They are not expensive and make the job much easier and don't damage the lock ring. Google "fuel tank lock ring removal tool" to see what I'm talking about.
