I was reading about a guy in the states who did a 'LCI conversion' to his E90 by sticking red tinting on his tail lights. While this is in no means an 'LCI conversion' I thought it looked so much nicer than the clear reverse lights so I bought some pre-cut tint from the states and put it on today. Its not perfect with some tiny air bubbles but I'm hoping that by leaving them in the sun they might go away, I think it looks so much better as the tail lights are, for me, the weakest design link on this car.
  • Like 2
imageproxy.php?img=&key=4b1e78680f916b86
Um but do they glow red when you are going backwards? Would be illegal and confusing.
  • 4 months later...
I just realised how long its been since I updated this.
So, I'll add what I've done since March.
Oh, also, my VVT motor is leaking oil into the spark plug holes #3 & #4. Its not much of a leak but its causing the odd miss which is irritating me. Been quoted $800 but it looks pretty straight forward and might give it a go myself.
Also, during my must-keep-warranty 6 month oil change my intake pipe was noticed to be not entirely attached allowing unmetered air into the engine. This was fixed which made the car a little more responsive.
I changed my angel eye bulbs to LED's. I purposefully didn't get stupidly overpowered ones as I didn't want the angel eyes to be like little suns, I just wanted them whiter than the halogens and slightly more noticable.
Here's drivers side done, but not passenger. Fairly different, passenger doesn't even appear on.
Both done in the daylight.
Here they are at night. Not bright enough to light anything up, which was the desired effect.
I need to get pics of my interior changes...
But, I totally had enough of my seats. They were horribly uncomfortable and like sitting on a bench.
I got some absolutely mint M-Sport seats. They are soft and the leather is gorgeous. Lots of left and right thigh support and an extended thigh base at the front. They also have air-filled bolsters though if you are larger than the average 3 year old you may need to leave them empty as they get seriously tight.
I also picked up a BMW Individual steering wheel! Its so fricken cool though a little banged up. I'm trying to bring it back to its former glory but its already so much nicer to drive with than the bus wheel that was in it before.
One thing I noticed on the car the first time I saw it was the terrible state of the window seal trims. The front windscreen is totally missing and the rear just looked horrible.
Here's how it looked and it was killing me every time I looked at the back of the car.
The other issue was that somebody had glued these pieces on which was a real mess.
Anyway, once they were all off I gave the glass and the car underneath a good clean and then a spray with silicon to assist in getting the new trims on.
End result is so nice. Its one of those changes you make that you keep noticing every time you look at the car. Seriously satisfying, its been eating at me since I bought it.
Some black glue still on the paint to this day, need to hit it with some bug and tar remover.
Passenger side isn't perfect but no amount of manipulation would fix it. I just left it, as its not glued in I might try to fix another time.20180721_150442.jpg
My drivers side tail light has always been cracked. I picked up a replacement and its another satisfying fix. Its so much cleaner than the other side though I'm now considering buying its pair to make both sides nice and clean.
Anybody know how to get this off? Its so irritating and no amount of scrubbing even makes a dent.
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
    • I know right. It baffled me. There's no way when the engine is off, key is in ignition, (coils are dissconnected aswell), also my sound system was dissconnected (I don't run any audio capacitors), battery reads 12.2v and with the 10amp fuse blown I was measuring 24 to 30v. The reading would move a bit from 30v to 24v which was weird. I took a pic of the multi meter reading 🤣: (This is a brand new single channel digital oscilloscope that also has a multi meter mode).   Before when the fuse was blown, I had one lead on the 12v supply (green/white wires) of that brown relay and the other lead on the negative battery terminal. When I turned the key on ignition (engine off), it would read 30v. Then when I removed that relay from it's plug and tried putting ignition on again, it would read 12v, but I think it's because it can't turn on the ecu now that I removed it. I asked Chatgpt and this is what it had to say:   Not sure if those theories would be possible but, any auto sparkies here? welcome to confirm. 🤷‍♂️  No idea, but if it happens again, atleast I know what type of issue it is, unlike last few months where I didn't know what was causing all my issues and I was just taking stabs in the dark to figure out what type of problem it was. If it does happen again I'm going to investigate futher and trace back the source even more and inspect more circuits. I drove it to work this morning and the car drove and boosted fine. Yeah I was thinking the same, so I've imported my back up saved map (which is the map that I saved when it got done tuning) back onto my haltech with the base fuel pressure set to 43.5psi.
    • Yeh nice, if your in melbourne could you recommend any exhaust shops in the east that do a good job?
    • Sorry yes, this is what im after Also, that jpjdm site appears to be offline
