Hi all,
Got a bit of an issue with my V35 manual coupe.
Wondering if anyone has any ideas what could be causing the sound in attached video?
  • Happens when decelerating from anything over 80km/h
  • Steering wheel will shake sometimes, other times it doesn't.
  • The noise is present without braking
  • Wheels and tyres are fine - IMPUL F919S with new Federal 595RSRs
  • Noise appears to be coming from drivers front wheel area
  • Calipers are not stuck
I've put the car up in the air and can't find anything visually wrong underneath. Spun the wheels by hand, sounds normal.
Was hoping it would be a wheel bearing, but now I'm not so sure.
Any ideas?
received_1749827491756552.mp4
Edited by nicholascleef
have you checked for loose plastic inner guard covers, sounds like something slapping around in there, maybe some of the plastic clips have broken?
Other than that, possibly bad bushes.  Does the noise go away if you apply brakes?
The noise doesn't go away if I apply brakes, nor if I put the clutch in. Inner guards etc are all secure and as normal. The noise only goes away once the vehicle has slowed down to below 80km/h regardless of whether I apply the brakes or just let the car gradually slow down.
Has brand new rotors and pads. Clutch is brand new too - Exedy heavy duty, single mass flywheel conversion.
Front lower arm bushes and lower ball joints replaced also. All this work was done less than 5,000km ago, car has been driving fine until recently.
Noise started occurring when I was giving it the beans, so I've obviously damaged something.
I know you said the guards are secure but plus one on sounding like loose plastic.
I had an issue awhile ago where one of the smaller plastic covers that links to the undertray was loose.
Wind would hit it at certain speed, get partially trapped and would make noise.
hmm.. if it was bushes, I would expected to have seen some change with brakes, possibly steering linkages, but I would think that would be more obvious.
I know you checked, but the only thing I can think of that lines up with the symptoms well is a loose splash guard or fender liner.
Giving it a boot full of throttle shouldn't have broken anything in the front suspension, it is just there to steer and brake.
Thanks everyone for the responses. The noise ended up being the under tray, some of the clips were broken, hence it was partially loose. Not sure how I didn't notice this the first time I had the car up on the hoist. Obviously it was catching the wind at 80km/h+.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
