Hi all,
Got a bit of an issue with my V35 manual coupe.
Wondering if anyone has any ideas what could be causing the sound in attached video?
  • Happens when decelerating from anything over 80km/h
  • Steering wheel will shake sometimes, other times it doesn't.
  • The noise is present without braking
  • Wheels and tyres are fine - IMPUL F919S with new Federal 595RSRs
  • Noise appears to be coming from drivers front wheel area
  • Calipers are not stuck
I've put the car up in the air and can't find anything visually wrong underneath. Spun the wheels by hand, sounds normal.
Was hoping it would be a wheel bearing, but now I'm not so sure.
Any ideas?
received_1749827491756552.mp4
Edited by nicholascleef
have you checked for loose plastic inner guard covers, sounds like something slapping around in there, maybe some of the plastic clips have broken?
Other than that, possibly bad bushes.  Does the noise go away if you apply brakes?
The noise doesn't go away if I apply brakes, nor if I put the clutch in. Inner guards etc are all secure and as normal. The noise only goes away once the vehicle has slowed down to below 80km/h regardless of whether I apply the brakes or just let the car gradually slow down.
Has brand new rotors and pads. Clutch is brand new too - Exedy heavy duty, single mass flywheel conversion.
Front lower arm bushes and lower ball joints replaced also. All this work was done less than 5,000km ago, car has been driving fine until recently.
Noise started occurring when I was giving it the beans, so I've obviously damaged something.
I know you said the guards are secure but plus one on sounding like loose plastic.
I had an issue awhile ago where one of the smaller plastic covers that links to the undertray was loose.
Wind would hit it at certain speed, get partially trapped and would make noise.
hmm.. if it was bushes, I would expected to have seen some change with brakes, possibly steering linkages, but I would think that would be more obvious.
I know you checked, but the only thing I can think of that lines up with the symptoms well is a loose splash guard or fender liner.
Giving it a boot full of throttle shouldn't have broken anything in the front suspension, it is just there to steer and brake.
Thanks everyone for the responses. The noise ended up being the under tray, some of the clips were broken, hence it was partially loose. Not sure how I didn't notice this the first time I had the car up on the hoist. Obviously it was catching the wind at 80km/h+.
    • yeah first and reverse is where you will find clutch release issues (whether hydraulic or mechanical) because the difference in revs required is the highest there; particularly changing down from 2nd to 1st when still moving. To be clearer though, it is possible that the clutch release bearing is the wrong height. This is less likely than a hydraulic issue but it is not unheard of when you are mixing and matching
    • Quite right, if you make it to that pension you deserve every cent
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
