Hi guys having major problems with the brakes on my r33 skyline gtst non abs.
There is no leaks at the calipers, master cylinder or anywhere on the brake lines everything is solid.
With the engine off you pump the brakes 3 times they sit high and hard with no pressure drop if you apply consistent pressure (Master Cylinder is 100%)
Once you turn the engine on, the brake pedal drops to half travel if you put a bit of pressure on it and the braking doesnt feel the best. I cannot for the life of me think what is wrong, I have swapped out the master cylinder and brake booster from my friends 33 which has great pedal feel. Has been properly bled 3 times there is literally no bubbles in the system at all.
Manual bleed, vacuum bleed, reverse pressure bled.
Bought 2 metres of clear line and made sure there was no bubbles it is definitely bled right it is driving me crazy.
Thank you.
https://www.sau.com.au/forums/topic/472911-brake-problems-r33-gtst-non-abs/
1 hour ago, Dobz said:
So it’s high and hard before you turn her on, once she’s turned on it drops half way and softens up?
Serious now, have you played around with the pedal adjustment?
#Brazzers
No haven't played with the pedal adjustment, comparing it to my friends measuring the length of the thread thru the nut on the brake pedal assembly mine sticks out 5.2mm and his is 5.1mm with a bit of error in measurement due to the difficulty of getting the vernier in there it is the same.
If you think it will fix it might give it a shot tonight look up a tutorial now.
    • It is not a dual mass flywheel, so you will get some gear noise on a BNR34 unless you deviate from the OEM fluid spec and run a thick gear oil like what Nismo recommended for a while. Unfortunately I have never weighed the flywheel by itself prior to installation but it is not that light. It's probably an 8-9 kg flywheel. OEM BNR34 dual mass flywheel is like 14 kg which is kind of hilariously heavy.
    • Got around to installing the Tomei Cam Cap Studs and the Hypertune cam baffles/splash guards. Unfortunately, I was not aware that the cam cap studs do not clear the stock RB25 internal cam cover baffles. Some research found a set from boostdoc which includes a replacement cam cover baffle and full length cam baffle + tools and fasteners. but I'm not keen on re-buying what I have already bought. So the plan is to take the hard route and modify the existing cam cover baffles to clear both the cam cap studs and the hypertune cam baffle plate. I assume there must be people who have gone through this even just to convert from cam cap bolts to cam cap studs? If so any tips would be appreciated. Otherwise I think I will mark where the cam cap studs foul, drill clearance holes in the cam cover baffle, and remove the cam cover baffle oil returns to clear the  hypertune baffle plate. I will also need to remove the baffle and drill and tap threads to bolt it back on so i can clean out any swarf. Fuel tank foam as extra cam cover baffling?
    • The incoming weather event seems to be affecting people in weird ways....🤣 And no, whilst there is some fancy engineering going on, I have no real interest in anything rotary really I had a Capella in the 90's, the rotary engine is way to temperamental, and extremely thirsty for my liking  If I won lotto and wanted to waste a ton of cash, a boosted K-swap would be what I would look at, until then, the N/A MZR2.5 will be at home in the engine bay of the NC A build like this, just without the idiotic street pulls and skids would be interesting to waste a huge amount of money on https://youtu.be/EgqAoVtUD1E?si=n3_umivrUPP8C9Cs
    • Now we're getting somewhere. All we need is a fractional rotor system so we can also have the RX3 and 5 back, and the world will be right again.
    • With that engine being a one rotor, would that make this into an RX4?
