R32 RB20 cross over pipe, BOV $50
2x GTR BOVs $30ea
IMG_20170429_133743_zpsupmy8nuc.jpg&key=a0b631ca52b57045489c46cd11d5247f0fd0ea7a53488e43ed35cf28a647f813
6x Intercooler Clamps (HD) $20
IMG_20170429_133817_zps9hqtvgkb.jpg&key=7bbe10eee3d0f5e0c5a1da035d3d0e4f732a996c3de5969cf37201d31b421945
RB20/26 Cam Gears $10
IMG_20170429_133827_zpsc9cvqcdj.jpg&key=62ae72bb357cc4776a8524468b1d3cc53e1a4e70e483a5d22f5cbd8d1c44031d
Walbro Fuel Pump pickup extension (E85 Safe) $40 - only test fitted
IMG_20170429_133749_zpsilgn4oib.jpg&key=2fdde576114ddf5b928d06e3516a075886aa7ff2aa83be8716180cfd047724bc
52mm coilover sleeve x2 & gland nuts x4 $50
IMG_20170429_133727_zpsg9uxzkvl.jpg&key=300ffff41cac4f64ec9822c3f39dff29993cba9502cae43adf7d61cc545107c4
R32 standard RB20 intake plenum (upper & lower) w/bracket for R31 $50
IMG_20170429_133700_zps4suclk0d.jpg&key=20fe5eb27d01ae120efac036bcd2e536941c118cd5a8b7efdd1c3a34df1fd40a
R32 RB20 water pipe (new) $100
R32 rb20 Front facing plenum.
Machined flat in a jig to ensure that it's straight.
Includes PFI fuel rail, throttle cable.
Can throw in new water pipe.
$500
R33 crossover pipe W/standard bov $50
With GTR bov $70
R33 gtst intake, injectors and rail $100
R33 gtst loom $100
R33 gtst auto ECU $50
R33 gtst S1 hotside.
Turbo, manifold, oil and water lines.
Awesome rb20 upgrade.
$300
R33 rb25 ignightor and coil pack loom $100
R33 rb25 oil filter heater hoses and oil filter housing $50
Located Western Suburbs of Melbourne.
Pickup or can post at buyers expense.
https://www.sau.com.au/forums/topic/472925-shed-clean-out-rb20-25-30-parts/
  • 4 weeks later...
Ill take this guy if you still have it, tried to pm but said you couldnt receive it.
Can you post to nsw 2566, thanks Russell
Sure.
Not sure about the PM thing.
Will try to send you an PM with payment deets.
Postage will probably be between 10-20.
Will get a quote.
R33 turbo, fuel rail and injectors sold.
R33 GTST intake with all sensors, now $50
Have R33 GTST rack ends available $40pr
Rb20det front facing plenum & fuel rail dropped to $400
    • I’m doing some side developments on SR20det S13 engines, its one my hobby cars used it to compare flow capacity of some smaller size wheels. SR20det is one of another JDM legendary engines I'm sure there are plenty of SR enthusiasts on this forum, I will share results some common turbo configurations here. a quick run down of what the car is: Wide body 180sx Type X with black top engine (blue). It has: Stock bottom end Haltech 1500 ECU 5-0 motorsports trigger kit Kelford SR20DET Beehive Spring with Titanium Retainers Kelford Cams SR20DET S13 188-B 268/272 Cams G25-660 Turbocharger in T2 .64 rear housing internally gated ARP Head studs MLS head gasket 1000CC ID injectors Walbro 450L Fuel pump Front mount cooler kit JJR’s 3 inches turbo back exhaust (its too short for the 180sx it had to be extended) Pump 98 fuel Hub Dyno tune So far made 270rwkws at 22psi full boost by 4500RPM. Engine is very knock limited hence a pretty bad looking top end. From previous experiences it seems like SR20dets are happier with bigger size turbine, some thing like a GT30 would make way better top end, but on same time response is lost. It won't be a problem with S15 VCT engines. I'll be testing alternative turbine housing, turbine wheel and possibly dump pipe options for extra flow to resolve the problem and of course E85 would resolve all the issues.
    • Awesome writeup and details. Thanks for sharing the story so far. I can relate to parts of it with my previous car and some of the issues I had to deal with.
    • Wow the colour matched hard top completely transforms the car. Are there any nice front lip options for the car or is that off the table?
    • Generally yes but for some reason I've been ruthless this time around!  I might even need to do another tip run after the way I've finally been able to hit the delete button on shit I've stepped over, stepped around and tripped over for the past 10 years!
    • I just quote the Rolling Stones. Paint it black.
