R324u Posted December 16, 2017 Share Posted December 16, 2017 I've read a few things that the S14 and ECR33 share the same Front Lower Control Arms and others say their different.. Not sure which is correct, I am looking to place these on my R32 GTST, Any Help would be greatly appreciated! Link to comment https://www.sau.com.au/forums/topic/472933-ecr33-front-lower-control-arms-s14-240sx/ Share on other sites More sharing options...
bcozican Posted December 17, 2017 Share Posted December 17, 2017 (edited) Think they are the same they will fit yes but I used s14 ones.....depending on your cars other suspension ie: adjustable or stock it may cause problems. either way you'll need a wheel alignment when you put them in They are 10 - 15mm longer than standard r32 gtst hence, without any other adjustment and all other things remaining equal, you'll be running more camber and your castor rods may not be long enough Edited December 17, 2017 by bcozican 1 Link to comment https://www.sau.com.au/forums/topic/472933-ecr33-front-lower-control-arms-s14-240sx/#findComment-7862686 Share on other sites More sharing options...
GTSBoy Posted December 18, 2017 Share Posted December 18, 2017 Not to mention the roll centre problems, etc. 1 Link to comment https://www.sau.com.au/forums/topic/472933-ecr33-front-lower-control-arms-s14-240sx/#findComment-7862697 Share on other sites More sharing options...
R324u Posted December 18, 2017 Author Share Posted December 18, 2017 I have aftermarket Cusco adjustable pillow tension rods , So might be ok in that aspect. Just trying to figure out my options for the moment thank you guys! Link to comment https://www.sau.com.au/forums/topic/472933-ecr33-front-lower-control-arms-s14-240sx/#findComment-7862726 Share on other sites More sharing options...
