1990 Nissan Skyline R32 GTR I have owned this car since 2007 and have converted it into a track car from road use myself. Virtually everything has been rebuilt or replaced, with most of the engine & drivetrain doing only 1 track day after rebuild. The car is very well known amongst Skyline enthusiasts and has rarely been driven hard but is ready to race and is truly reliable The car has the Following modifications: Fully rebuilt engine with forged pistons <1hr track time - Fully rebuilt front and rear diff <1hr track time - Fully rebuilt transfer case <1hr track time - Fully rebuilt gearbox <1hr track time - D2 356mm front brakes (3 track days) - Full tein suspension - Exhaust - Custom race side pipes - Haltech ECU tuned to 297kw - Full steel cage with side intrusion bars and taxi rail - 18 inch Panasport G7's w/ Hankook semis 95% wear - FullRace ETS Pro 4WD ECU replacement and Digital G sensor - Hicas removal kit - Wheel aligned and corner weighted by Heasman's - Oil Surge Tank - Fuel Surge tank w/ twin Bosch 044 pumps (suitable for E85) - Twin Garrett GT2860-7 turbos - Racing radiator - Extended Sump with baffled gates - Full body respray in Calsonic Blue and full livery. Very straight body. Interior cage and floor sprayed in black/grey Less
$35,000 ONO. PM if interested.
  • Like 2
https://www.sau.com.au/forums/topic/472936-r32-gtr-calsonic-replica-track-car/
5 hours ago, BlueThirtyFour said:
Registerable?
You would need to cut the cage out and get a blue slip. I have a veilside exhaust to replace the side pipes. I would make your own enquiries in regards to rego being possible or not.
Also reason I am selling is to invest in an enduro/IPRA car with my brother. Running two cars is proving too difficult and this car is far too nice to go enduro racing in.
Check the build thread in my sig it has a gallery of photos documenting the build. Cheers
  • 3 weeks later...
    • Update 2: Today I'm f**king pissed. Some of you probably saw my thread that I opened shortly after joining this forum, "urgently need expert/experienced opinion", in which I discussed the possibility of a porous RB26 engine block which I also found hard to believe. Currently both turbos are out since the shitty braided line that was installed by whoever fitted the GT28 turbos leaked oil onto the exhaust. Today while working on the cam covers to put new gaskets and half moons in, I cleaned the side of the engine block with brake cleaner. Some time later I saw that it was still glistening with oil or coolant so I dried that off. But it was wet again shortly after. Verdict: I'm royally screwed. What you can see here (hopefully, despite shit resolution), circled in red, is a crack above the turbo oil feed. Extent is a few cm long and basically goes from #3 cylinder wall to #4 cylinder wall. It slowly lets coolant through, even without any pressure behind it. I am absolutely dumbfounded as to how this crack even formed, especially since it isn't along the cylinder as it usually is but rather a horizontal crack. Probably a few cm in length. Not sure on how to deal with this issue right now. Most likely, the only true fix is a new engine block, and even a relatively well done temporary fix requires at least a full engine teardown. Neither of those really fit my timetable right now, the car has been in my buddy's garage long enough as it is. I'm open to suggestions, but I'll be looking into ordering a new 05U block soon so I have one ready for the coming year, or whenever the current block inevitably fails fully. (Most likely once the crack reaches one of the frost plugs) I think it'd be a waste of money and time to rebuild the engine with this block. Oh and I found a rust hole on the side pocket of the trunk, which someone covered up with sealant goop, a piece of number plate and bodywork filler. Fun times. So far for every issue we fix we just find a new one that is arguably worse.
    • I have not found this no. I put one back on a couple days ago with no drama. I agree they are tight, but no need to remove anything.
    • That is gates blue racing belt
    • Anyone found gates blue racing to be extremely tight/ almost impossible to install without moving the exhaust gear
    • Hello am apex am new here and also thanks for helping registering the forum
