SAU VIC Motorsport Dates 2018
acsplit
 Share
Time to lock in your calendars for 2018.
Here are our 2018 Motorsport track day events, we will add DECA/motorkhana dates to this in the new year with hopefully 3 rounds and at least one new venue.
We are still working on classes but this way you can lock in the first day which will be a come and try day at Broadford after the great feedback we got from last years event.
Everyone is welcome our events and if you are an SAU member you are eligible to be a part of the championship and will get discount entry to days that we run.
We have also created a public google calendar that you can add to your iPhone or android phone to see upcoming events.
SAU VIC Events iCal
Web Link to Calendar
Instructions for adding a google calendar
If anyone has any queries flick us an email [email protected]
25488874_10156586375249386_1148752393_n.thumb.jpg.39b28c2cc699a27ff719131007cdcaae.jpg
  • Like 3
  • 3 weeks later...
That iCal file has some personal calendar stuff in it from whoever created it. Might want to give it a look through and edit it (there's some personal info and bank details and stuff in there). I'd just delete every event in the calendar pre-2018 to make it easier. That's what I did in my copy now.
Thanks,
I have created a new calendar if you want to remove and add the new iCal.
  • 3 weeks later...
  • 4 weeks later...
 Share
    • You all are absolute legends! Thank you for helping me put this into context with your comparisons!
    • There's probably an underlying issue with the A/C system too. I recently fixed mine, now it's fully control by the Haltech and car's factory HVAC controller  Have a squiz here:
    • And by the way, I've also checked the ECU diagnostic numerous times and got a bad O2 sensor code and initially an Ignition Primary code, which is why I replaced the O2 sensor and all the ignition components (coil packa, plug and loom). No codes have been coming up lately despite the ongoing issue.
    • Hey pber13, unfortunately still no luck. At this point the following has been done with little or no success: - Spark plugs replaced, gapped to 0.8mm - Splitfire coilpacks installed to replace originals - Replaced Ignition Coil/Coilpack harness with a new genuine nissan one - New fuel filter - Replaced AFM/MAF sensor - Injectors have been thoroughly cleaned with an online flush (without removing) - Upper engine and inlet decarbed - blew tons of black smoke out, cleared the carbon deposits from the top of the engine and exhaust.  - IACV removed and thoroughly cleaned with carburettor cleaner - O2 sensor replaced with new and genuine one -  Smoke test revealed no vacuum leaks - Healthy compression test of 160psi across all 6 cylinders Overall the car does run a lot smoother now, no backfires between gear shifts like it did originally... but the rough idle when warmed up is still there. It may not even be a misfire but simply a rough idle. Seems crazy to me that so many people have had this issue and seemingly no one has gotten to the bottom of it, or at least never bothered to post if they did! Hope you have more luck than I did pber13, I'm at a point now where I'm just going to try to ignore it unless it gets worse. Would love to fix it but I've genuinely run out of ideas of what it could be.
    • I got the full frenchys kit too. Really awesome kit. Easy to install my only complaint was the hardlines I think could be routed differently (I modified mine) but I realise the kit needs to suit multiple applications. This was the hard lines before I modified them. They were touching the wastegate pipe. I ended up reducing the distance between firewall and first bend. The made it so they tucked along the frame rail.
