SAU VIC Motorsport Dates 2018
acsplit
 Share
Time to lock in your calendars for 2018.
Here are our 2018 Motorsport track day events, we will add DECA/motorkhana dates to this in the new year with hopefully 3 rounds and at least one new venue.
We are still working on classes but this way you can lock in the first day which will be a come and try day at Broadford after the great feedback we got from last years event.
Everyone is welcome our events and if you are an SAU member you are eligible to be a part of the championship and will get discount entry to days that we run.
We have also created a public google calendar that you can add to your iPhone or android phone to see upcoming events.
SAU VIC Events iCal
Web Link to Calendar
Instructions for adding a google calendar
If anyone has any queries flick us an email [email protected]
25488874_10156586375249386_1148752393_n.thumb.jpg.39b28c2cc699a27ff719131007cdcaae.jpg
  • Like 3
  • 3 weeks later...
That iCal file has some personal calendar stuff in it from whoever created it. Might want to give it a look through and edit it (there's some personal info and bank details and stuff in there). I'd just delete every event in the calendar pre-2018 to make it easier. That's what I did in my copy now.
Thanks,
I have created a new calendar if you want to remove and add the new iCal.
  • 3 weeks later...
  • 4 weeks later...
 Share
    • I am impressed with all this level of adjustment. I didn't expect all this possibility
    • Correct.  In the case of the 500kw dyno plot I showed you the car actually runs two boost control solenoids for boost control and a 5psi wastegate spring.  It allows me to control how much boost pressure is applied to both sides of the wastegate valve at any point and fairly accurately control boost target as a result. I've tuned it so that it's able to target anywhere from 5psi to 25psi depending on what's needed.  The target tables I've set up in that car are Gear vs RPM, so every gear has potential for a different boost (and torque) curve.   First and second gear have quite low boost targets, third gear actually has different target boost all the way through the rpm range as it's a stock RB25 gearbox - the boost targets have been chosen to maintain a peak of 600nm (what the owner has set as the maximum torque he's happy with putting through the stock 3rd gear) but it carries that to the rev limiter.   The boost curve to achieve that is something of a ramp up, then hold, then ramp up again and the power curve looks more like a flat line haha.
    • so you can decrease or increase the boost depending on the diet as you wish?     by acting on the wastegate?
    • That's torque and power, it's all from a single run.  The boost curve is "held back" from it's peak target in the 3500rpm to 5000rpm range from memory, so it ramps hard to something like 18psi then climbs more progressively to 23psi nearer 5000rpm.   It makes the torque (and power) ramp more "natural" and less hard on parts and traction, it doesn't feel artificially held back.
    • Here's the torque curves from the car I ramped boost up later in the rpm to allow a slightly wider useful power curve - the power curve is a bit weird shaped also thanks to the TVIS (or whatever they call it with the 4EFTE in this Starlet) which changes the volume of the intake manifold throughout the rpm range, but you can see that the green power curve actually holds later on with the extra boost... but looks almost more like the kind of thing you'd expect from a cam or exhaust change
