Hi Guys,
So I inherited a stripped out R32 GTT so I'm looking to get a simple music setup going (No HU present and No harness!)
Basically, I would like Nexus 7 > 3.5mm to RCA converter > Amplifier(small) > 2x front door Speakers
I have tried looking everywhere for this setup but finding inconclusive information. Can anyone point me in this direction with setup method or products?
I don't want the best sound possible - just something decent enough (OEM spec)
THANKS!
Should be pretty easy and cheap or as expensive as you want to go depending on brand
3.5mm to RCA: <$10
https://www.jbhifi.com.au/tv-home-entertainment/tv-accessories/belkin/belkin-essential-stereo-rca-to-3-5mm-audio-cable-2-0m/357294/
a 2-channel amp: $89 this will only run a small sub or 2 x speakers as you've mentioned
https://www.jbhifi.com.au/gps-car-audio/amplifiers/pioneer/pioneer-gm-a3702-2-channel-bridgeable-amplifier/318026/
and then your pick of speakers that fit, I"m guessing 6" usually in the front, there's not really much else to it, except a wiring kit and possibly some RCA female to male cables depending on where you install the amp.
The only tricky part now that i think of it, is you normally wire the power direct from the battery, and then there's a signal wire from the head unit which actually turns it on, so this signal wire I'm guessing you could wire up to an ignition or acc source to achieve the same thing
I can wire the power without it being an issue but my question is more over sound quality - surely it cant be this simple right?
Any need to DACs or pre-processing units (i don't know what they are, just words from my research!)
Yes it would work. How it would sound is another issue.
I'm sure if you went in to JB hifi where they have headunits, amps and speakers set up, you could ask them if you can plug your phone directly into the amp to test. might have to bring your own 3.5mm>RCA cable or buy one there
    • Do Alan and Keith work on Skylines now? I remember buying stuff from them when I owned my Ralliart Lancer a few moons ago. Definitely genuine guys and be excellent if they dealt with the skyline platform as well.
    • Hey all, I'm Gaston from Sydney's West.  I was a member on here when I was a younger lad and owned a mint R33 GTS-T. Ended up selling it and getting married having kids (yadda yadda) we all know how the story goes. Now I'm back with the intention to get my midlife crisis (dream) car ... a R35 GTR.  You'll see me about asking questions and searching the forums. Good to be back and can't wait to get back an Import again.
    • I have to put something here in order to post the photos. From what I could gather there's more enthusiasm for modified cars now than there has been for years. There were probably more younger people there than older (me included lol) which was a good sign.  It did seem like the record least amount of representation of the 90's era hero cars on display though. Like maybe one or two examples of S-chassis Nissans, and maybe 3 or 4 R-chassis. By comparison there were a lot of Civics from that era but in all there were about 10 - 12 EG/EK Civic Type R.  Euro exotics are always there in large numbers, led by Liberty Walk...... say what you will about kids using markers to scribble on a Ferrari F40, it did seem like a stunt to infuriate Ferrari enthusiasts, or Ferrari itself. I wonder if there's something more to it. Either way LBWK have done some heinous things to a Lamborghini Miura this time. They should stop now.
    • Engines and drivelines are not war stoppers for me mate, busted arse bodies and un-obtainium parts and panels are though Both cheap Brumbies I looked at had trashed tubs and a fair bit of rust
    • Stock O2 sensors are narrowband. They're useless once you're away from stoich. IE, useless for what you're trying to do. 10:1 will read the same as 14:1 from the stock O2 sensors. That is, they'll read rich. The same level of rich.
