Hi all,
Haven't posted on here before, so hopefully this is the right section!
Recently I encountered a problem where my R33 would not start. The engine cranks, but it will not catch and turn over. I checked all the basics: spark plugs were fouled, changed out with new matching plugs with same gap, coils firing, injectors pulsing, getting fuel, no cooling pipe leaks that I can see or hear. Eventually I had someone come round and the only way we could get the car started was to physically advance the CAS timing slightly and the engine fires right up.
I'm running some light modifications:
  • PowerFC (car has been tuned etc..)
  • GTX3076r Turbo
  • 740cc injectors
  • Z32 AFM
  • Walbro pump (not sure which one)
  • LS1 coilpacks (direct on coil incl. igniter)
Once the car is idling with the timing advanced slightly, the powerFC is showing 20 degrees, with my base ignition timing being 15 degrees originally. The maps and settings on ECU have not been changed since it was tuned several years ago and has run perfectly fine for years, so I'm wondering if I'm most likely looking at an issue with timing belt jumping some teeth?
Any insight would be great! I don't have a timing light at the moment and wanted to see what some thoughts were before trying to start working out how to verify alignment of everything.
Cheers!
https://www.sau.com.au/forums/topic/472948-rb25-gtst-timing-issue/
Thanks Odium :P
Yeah, timing was definitely off after checking with timing gun. Turns out, the harmonic balancer was loose and there's significant damage to the keyway/crank from excess play over time. My mechanic is hestitant to do any type of repair work and is straight up recommending a reconditioned engine. What do you think would be my best course of action in this situation?
I am looking to get rid of the car as I don't have the time or money to invest more into it. Might have to look into parting out all the aftermarket stuff on the forums :(
    • You are perhaps suggesting that it is not a super car? Well....it's not an AU.
    • Dropped the MX5 of this morning to get the hardtop colour matched and some PDR done, they are also going to give it a buff to remove some "stubborn" swirl marks and light scratches in the clear coat Over the last few months the poor little thing has copped some shopping centre car park abuse, I try to not park in them, but hitting Westfield's a few times over the last few months has taken its toll, nothing really bad, but enough of a trigger for a "while we're in there" thingie  Once it's back and all the one colour, with a few dents and mark's removed I'll give some of these products a go and see what they're like
    • A locally delivered Infiniti have remote start installed but don't come with the remote start key. You need a new remote start key and they just need it programed. And this is different to making/programing a new key that just starts the car.
    • Cheers, and cheers for sharing so much of the build and also sharing the glimpse of what turns out to bring a lot of us poor decision makers together haha.  I do recommend learning more about how to manage it, if not considering getting a  formal diagnosis.  The discussion with the psychiatrist I got my diagnosis through was quite eye opening, things I'd not even considered to be ADHD related and hadn't mentioned were things she asked about out of the blue and were common themes with people with my flavour of ADHD.   It's not a label for people who are hyperactive and ill-attentive, there's more to it than that and some of it can be much more challenging or damaging - though there are of course two sides to the thing, and a lot of the stuff we have to go through and work on to live with it make us effectively "better" at other things as well. Aside from the fact that there is some argument I could have a bit of ASD seasoning in there (came up during the diagnosis, and neurodiverse things seem to not stay as a cookie cut) I suspect you need to learn more about ADHD if you are puzzled about how hyperfocus could possibly apply.  I *do* personally use "superpower" with quotes deliberately, but it's 100% an ADHD thing due to the exact reason that lack of focus is also an ADHD thing... Loosely speaking the inattentive side of ADHD isn't the inability to focus, it's the inability to control where the focus goes.  Not being able to sleep because brain is more interested in thinking about a stupid thing I said to a girl I liked 30 years ago, not being able to focus on work because my brain is more keen on putting together the torque management strategy we're going to try out with a drag car next weekend, not being able to focus on a conversation with someone I WANT to listen to and respect because there is a flickering light in my peripheral vision.    If I could just stop work and build the torque management setup right there and then I'd not hear anything else until it was done.
