Using the NM35 aux fan
MrStabby
 Share
On the 32 GTR, this hack;
uses a diode to make the auxiliary fan come on when the air con is turned on. On the 32 It seemed to keep the coolant temp down and the cabin cooler. I'd like to try it on the Stag. Looks like there's no relay/fuses for air con presented at the wiring junction near the battery.
Has anyone got a wiring diagram or a translation for the footwell fuse box?
Other than waiting until the next overheat, how would i check that the aux fan is running at all?
  • Like 1
  • 2 months later...
Ok, so the hydraulic clutch on the main fan was completely stuffed. When moving it has a lot of momentum, but once i slowed it down (youtube search "how to test a viscous fan clutch"), I could hold it still with my pinkie finger. Have refilled it and the air it moves sounds like an old v8!
 Share
