So I know I might get judged really badly for this but I need assistance. Like an idiot I filled up my tank with 91 octane because there were no other options since I was driving out of town (I live in a very rural area). I didnt get any issues initially and the car drove fine. However, today the car misfired and my check engine light is now on and is staying on. Could that be because of the fuel or would it be an issue with the coil packs?
Please help.
https://www.sau.com.au/forums/topic/472959-check-engine-light-on/
running on 91 is perfectly safe assuming you were just pottering around. If you floored it up a hill and noticed but ignored the sound of a small rock rattling in a tin then you've likely f**ked your engine.
Is the car idling and running OK? Do you have 98 in it again now?
It's most likely not related to the fuel, but you still need to find out what the error code is.  Any local mechanic could put a scanner on it, or like Callan said there would be a tutorial on here somewhere on how to get it into diagnostic mode to tell you what the error is
I did floor it a bit. not completely and it was not uphill. The car misfired and since then I've only been driving really gently. The car runs fine for now. I haven't put 98 in yet because im still on a quarter with the 91 fuel. If i am right, when it goes to half, I could fuel up with 98 then to make it closer to a 95? I might give the diagnostic tutorial a go and see what pops up.
Yeah, I'd fuel up at 1/4 tank with 98 and yes you end up with the average octane so that will be OK.
I've been caught a few times without high octane when I'm out and about and it's fine. Actually back in the day when I was out at Alice Springs for 6 months my old 33 ran on only 91 and it survived OK....you only need the whole octane rating at maximum torque / maximum load. So if you aren't flooring it up a long hill in 4th at full boost it's fine.  Aftermarket tunes are almost always less tolerant to make more power but factory is pretty safe.
So a quick update. I drove to work this morning and drove it gently again as i did for the past few trips. The engine light check went off on its own and hasnt appeared since. I'll keep on driving it gently and maybe after putting 98 in and waiting for a day or two, ill try to floor it and see if it misfires.
That's my issue, i live in katherine and to get premium fuel here is quite hard. Only a few places provide it but after this has happened I definitely will ensure that I always have premium fuel in.
If you can control yourself it's safe enough....its just hard to be good all the time :)
The quick option is to lower the base timing by 2-3o, that should make the factory tune safe on 91. Just need a timing light to do it correctly. Of course it won't be as crisp in the midrange but at least it will be safe on low octane
So update again. after two trips the engine light came back on. I stopped the car. started it again and drove for around 200 metres and it went off again. This has already happened twice today so I'm quite concerned. I did the self diagnostic as well and it came back with code 55 meaning everything is fine. Also topped up with 98 just before. How long would it normally take for the fuel to mix properly and make a higher rating? Not willing to floor it yet just in case I get more misfire and damage the car.
Edited by Hacexd
well, that sort of depends whether it's actually on boost when the gauge doesn't work or not :P
a missfire can stop the engine running well enough to create decent boost.  Alternatively, an electrical issue like a bad earth, dying alternator etc could also cause a misfire. There's just too many reasons to really guess without more information.
Is your current situation that you have mostly 98 on board, you drove it 5 times yesterday, you haven't had a MIL for the last 3 trips, and it missfires? And where specifically does it misfire, approx which revs? And does it misfire if you free rev it or only when you are driving it properly under load?
If it is just light missfire in the mid range under load it is most likely a spark plug or coil pack issue. start by pulling the plugs out and checking their condition and gap. If the gap is over 0.8mm gap them down to that and see how that goes.
I might try to bring it to a mechanic on wednesday and see if they can find anything because as you've said, there are a lot of possibilities here. I filled up 98 when I was around half a tank on 91. No I haven't had a MIL for the few trips that I've done and yes it still does misfire. It probably misfires around 4.5-5k revs i would say. It only misfires when driving it properly under load. I do have to rev the car quite high to make it happen as well. The car just hesitates for a bit when it reaches the revs I specified and then after a few seconds it gets a sudden surge of acceleration like it should.
I was actually thinking spark plug or coil pack as well but at the same time, I just talked to the previous owner (I had the car for a week now) and I asked him if he changed the fuel filter and he did say that he doesnt recall when he changed it. So i might get the fuel filter changed as well and see the results.
The only issue with all of this is knowing exactly what's going wrong and I hope the diagnosis will find out the specific problem.
Thanks a lot everyone for your help as well.
I had this once after switching fuel brands, all 98
I’d been running on BP for ages and then out some Mobil 98 in, and got the check light after giving it a bit
The code it threw up was the O2 sensor
It did it a few times but haven’t seen it since. That was about 4 years ago
So quick update again. Ended up getting a fuel injector cleaner. I put it in the fuel tank and fueled up with 98 again and dropped the psi a bit on the turbo and car is running fine. No more hesitation on boost at all. Potentially just needed to be fueled up again I believe. I would also like to help everyone for your help on this matter. I spent a whole week worrying about what it could be and reading about it day and night on every forums lol. All solved though.
    • Details: Turbo Borg Warner EFR 9180 with 1.05 rear housing Upgraded TurboSmart integrated BOV Sanded and powdercoated compressor cover in gloss black Elbow welded with wiggins clamp Speed Sensor(Not included) (Can include oil drain(heat wrapped + titanium intake pipe with almost new filter for a tad extra). Manifold: 6 Boost RB26/30 twin scroll manifold  e-MAP ports drilled into both scrolls(I was using the TAARKS EMAP KIT) Turbo is in excellent condition. Always used Penrite 15w50 Racing oil(Changed less then 2000ks). Also using the Turbosmart OP regulator and filter. Downpipe: 4inch Stainless steel with VBand inlet and outlet clamps(included) Heat wrapped Dual ports for Dyno/Wideband usage Will throw in free 2.5 inch intercooler pipe(2.5inch From turbo outlet to 3.5 inch intercooler) - Powder coated black. Turbo made 563rwkw on mainline hub dyno at around 24-25psi boost - Pump fuel. Will def make over 600kw on e85. Didn't bother as my e-MAP was through the roof with my setup sitting past the choke line. I have a cnc ported and fully built head on my 3.2. Turbine speed saw max of around 109k rpm. I'm running this on my R32 GTR, with AC, and the original power steering pump. The manifold clears the AC lines, ABS, and everything else. Although I had new AC lines because I just wanted new ones and I heat wrapped them as well. This will make more power on a slightly lower capacity motor with a higher PR. And I have since upgraded to a G45-1500. Have pics and videos if need be.  Absolutely nothing wrong with setup. Turbo is in perfect condition. No shaft play or oil leaks at all. All the work was professionally done. The transient response of this is fkn amazing. I cannot rave more about this turbo. If I wasn't chasing 4 figures, I would have kept it. $5000 NZ. Located: Auckland, New Zealand.
    • I particularly like the look of the John Player Special team. (Thumbnail isn't different but hit play for the clip)
    • Such a cool collection of cars back then.
    • Mystery solved, thanks bro Bit of a strange mix, but i dont mind it, still looks good.
    • nah no problems with bearings or hubs.  just the water pump leak and my AC death
