Hi all,
long story short, removed cluster to clean cluster glass and cluster surround, now have only one globe left in the cluster that still works.
Globes work installed in anything else.
Is there anything in particular to look for on the back of the cluster that could cause this or do I start looking at wiring in the car to find the problem?
https://www.sau.com.au/forums/topic/472963-r33-cluster-lights-dead/
1. Plugs mated up correctly (pushed in till secure).
2. Fuse
If you didn't play with the wiring I highly doubt that's your issue. Although check for anything that has electrical tape wrapped around the wiring for the cluster.
  • Like 1
Are they LEDs or regular globes. LEDs have a polarity so if you took them out to clean it's possible you were just really unlucky putting them back in backwards.
It could also be an incorrectly mated plug to the dash where one of the earths has not lined up properly. Just check the pins are all straight on the plugs and plug them in again
  • Like 1
Anonymouse, have checked x2 times, replaced fuse. Only thing with tape is dimmer switch that gets added when they come to Aus. Seems a bit dodgy looking now that you mention it.
Duncan, has regular globes only, plugs look all good, copper tracing on back of cluster looks like new, no tears etc.
Spray some contact cleaner on the circuit board and plugs :blink:. 20yrs old might be something dry.
Each globe should light separately from each other so the fault has to be a common (why I thought a fuse). Earth wire somewhere?
No chance you've damaged the circuit board I hope.
  • Like 1
  • 3 weeks later...
    • Hello! I'm new here, I have an R33 GTST that is currently being finished up! Last year was pretty rough, blew two stock turbos so I decided to build the car. Has been down since November, but I get it back next weekend!
    • Hello, I believe my car was imported to America in the 2000s by Kaizo Industries. Would anyone be able to help me find more info on them? I've only found all the basic stuff like that paul walker bnr34, them being shutdown by feds, just stuff like that. Any help would be much appreciated, thanks!
    • I am using Motec M150.  I am not working on the car myself actually.  My workshop is giving all these info, they are quite reputable in the industry and are very familiar with Motec and RBs and have done a few big setups with VCam and single turbo on RBs.  In fact, they built and tuned my engine from day one.  But they are stumped with my engine at the moment and cannot work out how come the compression is so low with the VCam. They told me that they have now swapped in some Kelford cams (without the VCam) and can achieve around 130psi compression and the low end torque is better, but now the engine is doughy as.  It boosts and peaks at more than 1000rpm slower, with twin HKS GTIII RS, it doesn't get full boost until over 5000rpm. I have always thought the VCam was a bit disappointing at the low rpm. To a point I had to ride the clutch a fair bit to get up a small hill from stand still.  That was when I had a clutch.  Now changing to a 8HP, I don't have that luxury and this problem has become a major issue. I am beginning to think the VCam never work since the day it was installed.  Maybe it was just sitting at the most advanced point, that is why it went good at top end but very ordinary at the bottom.  Therefore, with the help of the Holinger 6 speed and paddle shift, as long as it was moving, it drove pretty good.
    • yeah, there's a country that recently started importing Skylines, I blame them.
    • I don't have a printer, but could at least attempt to make a printable model.
