Ok so I've come to the conclusion that there's no way I can get to this hose. I've decided I'll run another hose to bypass this one, should be much easier than trying to replace this one! >.<
Hi bro.... gee ya gunna hate it as i know its a prick... its a steel pipe section that runs behind the head yeah? It comes in a whole section with 2 pipes.. there is a nut in the center!!
That hose is a prick to replace [emoji21] i just replaced mine while i had the head off so it was super easy [emoji5] i actually replaced that entire metal coolant line and the rubber hose section with a braided line which can be purchased from most autobarn stores [emoji106]
Ok so I couldn’t find anywhere on a public holiday to get braided hose. Instead, I did find the perfect shaped heater hose for my application! Funnily enough, the hose I used was for the intake manifold of a 1992-1996 Magna. Go figure.
So, as mentioned in my second post, I’ve opted to completely bypass the original route for this hose. I’ve now run a length of hose from the original source at the back of the intake manifold, down the back of the head neatly tucked away, and I then used rotary tool to cut the hard coolant line to the turbo, slip on the new hose and clamped her up.
Pictures speak a thousand words. Might not be the ideal solution but it’ll work for me ?
After posting, I realised one of the pictures I uploaded was of those hose way in the air when I was fiddling around with placement - it didn’t stay at the top of the bay! :P I was able to route it down behind the head :)
4 minutes ago, Ben C34 said:
Did you flare the hard line where you cut it? If not solid chance it will leak
No sir, although I definitely should have! As this is a temporary solution I’ve opted to put a few layers of stretched silicon tape on the end, on which I slid the hose on and it was super tight and only went on with a little bit of rubber grease. I then clamped  her down good. I totally acknowledge this isn’t great long term and I’ll aim to sort out something more permanent when I next have a decent play under the bonnet.
4 minutes ago, admS15 said:
Good thinking, might be a good idea to wrap the end near the dump pipe with some sort of heat proof material or make a heat shield emoji106.png
Cheers - yeah that’s smart I might see what I can dig up
fuuarkk.. fun times :(
I've had that split on my current car (old motor) ended up replacing it with EFI hose and ran a braided china-spec ling long dim line to the turbo.
New motor has proper 4-ply eBay silicon hose to the braided water line lololol...
Someone come swap me their BMW 335i for my entire car/motor
  • 1 month later...
Same here I used a piece of good quality EFI hose .
For the record I would have used a couple of OE quality EFI hose clamps as well .
You can get at the mongrel on an R33 by removing the three bolt IAC housing and some of the wiring loom brackets in that area .
A .
  • Like 1
A bit late, but I replaced that hose on the Stagea (RB25DET NEO) the other week. Prick a job to get out, I used really long nose pliers and long nose bent pliers. To get to the clamp behind the engine I went horizontally from the intake side. I replaced the hose with Gates 8mm universal Z bend from Repco and new clamps.
I bought a seven piece radiator hose kit on Ebay, trying to workout where all these hoses go :/
  • Like 1
    • GTSBoy on your suggestion on another thread I had a look at those injectors and ended up getting them because of the quality.  Got the expensive ones.
    • Hey guys been looking everywhere to try and find the correct gtr hood latch support part number but only found the first half and when I search with that number it sends me to an r34. The first part I found was 62515. If anyone could help me with the rest then I’d really appreciate it. Or if there’s some alternative hood latch support that would work even better cause I can’t find any for sale. (Searched on upgarage, partsouq,buyee,rhdjapan)
    • If you've only done the upper control arms on the rear, AND you have changed their length (by more than about 1mm) to set the camber you want, then you will definitely need/want to install traction arms also. Adjusting the camber arms on their own WILL introduce bump steer and make the car unpleasant to drive. Most owners have no idea that their car could behave infinitely better than what they put up with. I'm not entirely sure what the Stageas need, but I am thinking that unless you have massive front spring rates and pretty soft rear springs, you have waaaay too much rear bar. Oversteer city, in my estimation. Combined with possible excessive bump steer from maladjusted arms, that could be a recipe for nastiness. ATR43SS2 is not a highflow. It is an outright replacement turbo. It's a little bit bigger than the largest highflow profile that Tao does. Probably a solid 300rwkW turbo where the bigger highflows will be about 30-40rwkW less. Nevertheless, we're only talking about ~300 rwkW, which is well within the abilities of the stock ECu to run with a Nistune on board. I would do so without hesitation - and I will be doing so when I get my finger out and actually get the injectors and AFM installed. But, if you would prefer to drop a whole lot more money on the ECU side, then I suspect you're looking at Haltech. The Haltech fanbois here will all spout on about all the available engine protection you can have, that you can't have with the Nistune option. And they're right. But it doesn't really come for free either. You will spend more money on extra sensors and the like, plus the work to install them. If the engine was built and therefore represented a big investment to protect, then I'd say definitely do it. If you view the current (and forever into the future) shortage of replacement engines as something to prompt similar protection, then also, do it. If you see a destroyed RB25 as an opportunity to put in a Mercedes or other V12 (like I kinda do)... then your perception of the risk/reward might differ. These are good injectors. You can also get a "better" set of the same with more flow matching, for more $$. 1000cc is where you will want to be. You will need an R35 AFM and adapter tube if you want to stay with Nistuned stock ECU. Otherwise, if going Haltech, you can ignore. As for intercooler. Just about anything will do. You're only talking about ~300rwkW. Just put a big core in there. Be aware that return flows do add significant pressure drop and will cost power and will make the turbo work harder to achieve the same goals. If you can manage a proper crossflow, do it. I'm keeping my very good return flow because I'm only expecting to be in the ~250rwkW range, and will live with whatever outcome I get.
    • I have a heap that i have collected if you want some authentic ones still. Pm me if your interested!
