Hi i'm a newbie so to speak, although i have owned skylines for the past 12 years in the UK
Just thought I would share a pic of my classic, and also see if anyone can help me source some parts to tidy up the rear of my 84 FJR30.
My R30 seems to be a bit of a rarity in the UK, its in excellent condition with no rust 77k/kms and a traceable history from Australia through New Zealand to the UK.
Also I'm travelling to Sydney end of January and wondered if there are likely to be any local car meets around then?
Regards Tim
https://www.sau.com.au/forums/topic/473003-84-r30-trunk-trim/
  • 1 month later...
