  • 1 month later...
So, getting back to this. A couple of days after i thought i solved my problems, the noise came back worse than ever.
I continued searching to no avail. A mechanical diff and drive shafts came up for sale cheap, i thought it was a good opportunity to upgrade and rule out the diff and shafts. Purchased and fitted, noise remained. Fuark, oh well at least ive now got a proper diff and better ratio for track duties (4.36).
I went as far as getting someone to drive the car while i was in the back and in the boot, all i got out of that was that it was below the floor and from rear right. Fed up with it all, i kept driving with the noise driving me nuts for a month or two.
Eventually, I decided the best course of action was to buy some chassis ears. I bought some ebay specials for $70. Best money ive ever spent (almost).
The noise was found to be coming from the forward rear right subframe bush. The chassis ear kit has 6 alligator clamps with mics in them i placed them at different locations on the rear right, 4 bushes, lower ball joint and tail shaft centre bearing. The offending bush was on the first channel i listened to. I couldn't believe it, was that simple to pin point using this cheap tool. On the other channels i couldn't hear knocking but could hear the normal sounds of bearings spinning, exhaust hum and even the brake pads brushing the rotors.
Now that i knew where the noise was coming from, i quickly jacked the car up, unbolted the bolts holding that bush and bracket up, 1 of the bolts holding the bracket didn't seem overly tight, from the bottom, the bush appeared to still be in 1 piece. I simply rotated the lock collars a little bit and refitted and torqued everything up.
Went for a drive and whoalla, no more stupid knocking noise. I wish i bought this tool at the beginning, would of saved around 10 hours of stuffing about and getting nowhere.
Here's a pic of the ebay spec chassis ears. They look uncannily similar to the sidchrome ones i was going to buy which are significantly dearer.
  • Like 1
Stupid forum media disabled crap. Here's the pic of the chassis ears.
Thanks to these, the problem is now solved and im going to put these to use to figure out where a suspension noise is coming from in our Stagea and the mrs Focus which started making a weird suspension squeak last week.
  On 07/03/2018 at 2:18 AM, hardsteppa said:
Those things look siiick. Do you have a link to the seller's ad pls? Ones i found on ebay were 300ish plus.
Expand
Yeah this is the link
https://www.ebay.com.au/itm/New-Auto-Car-Electronic-Stethoscope-Kit-Mechanic-Noise-Detection-Diagnosis-Tool/232374307192?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2055119.m1438.l2649
They work good, there is a little bit of static heard when you turn it on but nothing that stops you from hearing what you need. When the car is running, you don't even notice the static.
I also came across these, this is cheap as compared to other sellers of the same thing, looks pretty similar quality to be honest, headphone cord looks a bit better, the rest looks the same. The kincrome and sp tools version look exactly the same other than colours, they even have the same part numbers.
https://goodqualityproducts.com.au/product/sidchrome-car-engine-noise-detection-diagnos-electronic-stethoscope-
 if i was a mechanic and would get lots of use out of them, i would have gone for these wireless ones https://www.ebay.com.au/itm/Wireless-ChassisEAR/222300065562?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2055119.m1438.l2649 but with the limited use i need them for, the cheap ebay spec is perfect and adequate enough.
Found the issue in less than 2 minutes and took around 10 minutes to set up including jacking the car up and running the cables through the drivers window. I ended up just using compact ear phones to hear so i wouldn't look weird while driving around the back streets near home.
kit/
  • Like 1
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
    • When you pulled it off, there is no signs of blown head gasket? Is it possible you have some other issues going on? Possible cracked blocked? Or do you think it's straight up lifting the head? Did you check what the head was torqued to before pulling it down (To see if possibly they're stretching, or starting to break threads out etc)?
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
