Hey Guys,
Happy New Year.
I cant for the life of me get my Stagea (Series 2 RS4V Neo Auto) to convert into MPH. I have spent hours researching and each time find different instructions and wire colours.
Does anyone know what the wires are or have fitted one of these chips?
From my understanding
see uploaded image
I do not have a gey/yellow wire
Edited by tooleyrs4
https://www.sau.com.au/forums/topic/473015-kph-to-mph-conversion-wiring/
Those instructions only state wire colours for their converter so it's certainly not specific to stagea.  I've had one of these running in my stagea for about 10 years as a speedo corrector but I don't have the wiring handy; I will try and check in a couple of days when i do have the dash out.  But Bobby's suggested approach is the safest way; in most cases the back of the dash has printing that says what each track is (although sometimes it is in japanese as in the example he showed..)
Also, I've sent you a link to the manual
  On 02/01/2018 at 1:03 PM, KiwiRS4T said:
Expand
Yea i have tried the 5 wire way and still no joy.
What i am trying to find out is what colour wire / what connector pinout is the ECU / Transmission signal behind the cluster and what colour wire / what connector pinout is the speedo signal.
    • GTSboy, thank you again. i’ve been reading all the other SAU RB25 vacuum line threads and you have the utmost patience for people asking “where do my vacuum lines go”. it’s appreciated. i did also enlist a few other RB guys local to me.  i would like to run 5 to 4. turbo pressure side to wastegate actuator. i would like to run 3 to 1. power steering air valve line to intercooler outlet. (this is how it was previously). i was told 2 is the bleed port for the boost solenoid - which i’m not running - so should be capped.   anyone see any problems with that?
    • So yes. All of them. Something like 98% of all fuel in the USA has 10% ethanol: https://afdc.energy.gov/fuels/ethanol-fuel-basics It's labelled as like, AKI, 87, 91, 93 with an E10 or E5 or E15 label on the pump. At a certain point, it's not just "E10" instead of 91. It is 91, 95, 98, and all of them have 10% Ethanol in them. You can also get E85 and E30 which is why you do see some people rolling around with E30 tunes in them.
    • Thanks for the response. This is an 04 EP3 Type R. JDM spec. Fairly certain they're just basic BC racing coils. I do plan to keep as the ride quality on stock I've been told is pretty meh given Sydney roads. If I were to go down that avenue, does NSW require them to be a certain spec (close to original) etc?
    • Should have asked what is the car?
    • I've had two super conflicting experiences with blue slips. My 30 year old E39 waltzed through with no issues but my brother in law was knocked back on 12 y/o 3 series due to wiper blades and some cracking in a control arm bush.  What kind of coil overs? Do you want to keep them after?  If it was me I'd get some dirt cheap shocks and springs from eBay or scumtree. Not ideal but will get you over the line and might even be less than $1k.
