Hi guys,
I decided to start my build thread here at SAU.com.au as mentioned in my introduction thread a few weeks ago.
The car was imported from Japan in 2014. Completely OEM (RB25DET NEO, AT, Sedan, KR4, built in 1998, 50220km). No modifications were made, which was very important for me. A few scratches and small dents here and there... nothing special.
Due to the standards for registration here in Germany several things had to be done. This includes new lenses with an e-number (certified registration within the EU) for the headlights, a rear fog-lamp and new tires with an e-number, too. After that the car was ready for German streets.
In 2015 I bought a new Blitz Nur Spec RX as a replacement for the factory one and Nismo indicators.
It was a little strange to me that all the stickers (timing belt change, oil change, ...) were removed. And now comes the very - and with very I really mean fu**ing very very very very - bad thing about the car... The odometer reading was manipulated. During the change of the air purifier I've found a small sticker in the glovebox which says "Filter change at 86.xxx km" and a Japanese date (April/May 2009). Via the page japaneseodometercheck.com I figured out the correct odometer reading, which was around 100.218km at the time I bought the car. After that I decided to check the compression ratio of the engine. Well... guess what? Yes! They were not as good as expected.
In this moment I thought "God damn it! Let's drive the car intil the engine doesn't work anymore. Fu** off!". To my astonishment the engine survived 2015 and 2016. During the off season (October 2015 until April 2016) the transmission was swapped from AT to MT with parts of an wrecked ER34. I've done this by myself because I wanted to widen my skills and knowledge.
(That buddy really grew me some grey hair :D)
From March 2017 until August 2017 the engine was completely overhauled. Due to that process some aftermarket parts were fitted as well. ;)
The car now looks like this:
21587186_1491875224213038_3463246758906226593_o.thumb.jpg.0bded62023c4a7284f193756fb3692cd.jpg
Let's see what will happen to it in 2018. A few parts are stored in my garage... :)
If you want me to post my spec list just let me know.
Regards
Michael
Edited by n0va
  • Like 4
https://www.sau.com.au/forums/topic/473032-er34-sedan-by-n0va/
8 hours ago, Jordy32 said:
Cool car mate, welcome to the forum.
What's on the cards for 2018?
Thanks a lot!
The plans are as follows:
  • Blitz SE intercooler kit
  • Blitz RD oil cooler kit
  • Uras ducktail
  • Link G4+
  • GTX3071R
  • R35 injectors
  • Z32 MAF
  • Remap (ROZ 98)
Let's see what can be done in 2018. Hopefully all of it. :)
8 hours ago, GTSBoy said:
Yup, welcome to Jap import life.  To be clear, you should NEVER trust the indicated kms on the odo on any import.  Everybody here has known about it for 20+ years.  It's a fact of life.
Well... I was young and stupid. :D It should be obviously that not every sold JDM car has done ~100.000km after all those years. I've learned my lesson. Believe me.
  • 7 months later...
On 1/4/2018 at 9:27 PM, n0va said:
Thanks a lot!
  • Uras ducktail
  • Link G4+
  • GTX3071R
  • R35 injectors
  • Z32 MAF
  • Remap (ROZ 98)
Nice looking 4 door! What is remap (ROZ 98)? Ok looked it up you mean tune for 98 fuel. Have you got a good tuner lined up?
    • My idle is set at 950rpm though - Moving the timing around 20 degrees is not really what I'd call a calm idle. That said... neither is chop, by definition. The LS ECU likes to adjust timing to hold idle as opposed to air. It'd work, but generally speaking there'd be a discrepancy in the base idle and the IACV would want to move the timing around anyway to maintain said idle. I think I'm just going to keep the timing steady anyway. Preserve my engine mounts.  My aircon is now officially regassed. As the guy was reversing I noticed my reverse lights do not operate, along with my reverse cam. This is a bit distressing, because 100% of guides talk about which wire to connect to backup cams as "the goes with the [other color] wire". Often when doing conversions. Unfortunately the R34 colour wires aren't documented Unfortunately I had a T56 Magnum gearbox with it's reverse switch, which also isn't documented. Unfortunately there's definitely not documentation for people with both of these in the one car. Unfortunately I forgot. After many hours of this, I have a reverse cam and reverse lights again. The wire going through the trans tunnel to the reverse switch had broken. Upon inspection, it looks like this one wire had about 7 spade terminals and extensions in it.. for reasons I cannot possibly comprehend. I also spent the 750 hours required to clean up the wiring behind my head unit which now looks like this: This is a monumental improvement relative to what used to be there WRT triple gauges, head unit, traction control, wideband controller, and whatever the f**k OEM stuff still exists there in various states of connectivity/needed. Next step is to check in at the Exhaust shop to see/confirm how much clearance I have, to decide what mid mufflers or 'resonators' (which are just straight through, narrower mufflers) I can add and hopefully cut out a lot of exhaust leaks, pinhole, v-band or otherwise. But first step will be to 'take a look' before the next step.
    • Fark the AFM card and Nistune, Haltech Nexus S3, DBW, cruise control, flex fuel, dis dat.
    • It's most likely the bolt/bush where the cover bolts back wore and allowed cover to move forward.
    • Still haven't put the injectors and R35 AFM in so we can tune the bloody thing for the HG highflow it got mid last year! I think I can forecast the upgrade path to a bigger twin scroll, external gate, Haltech, flex setup, Samsonas, dis dat, etc will be .... a while away!
    • Should have taken that opportunity to slot in a twin scroll turbo setup. Maybe next time.
