This is FICs calculator .
https://fuelinjectorclinic.com/flow-calculator
For shits 'n giggles I entered 670 wheel Hp at 43.5 base pressure @ 85% DC and for 4 and 6 cylinders (injectors) . It came up with around 1860cc and 1250cc for 4 and 6 .
I think I prefer ASNUs ideas about making up their own diffuser plate cap fitting than the exposed ball valve . They have a version of the 1650 or whatever EV14 and you'd think it would break up the spray a bit better than a bare ball .
Edited by discopotato03
On 10/02/2018 at 6:47 PM, Mick_o said:
My 1300s are the same.
You went way too small if you'r aiming for 500kw Pete.
Piggy is at 87 or so % duty cycle with 1700s at 486kw.
74% mate ?
6 hours ago, Piggaz said:
Stock I’m fairly sure. Would have to confirm that though mate.
High chance that's stock pressure Paul, if they were at 3.5 or even 4 bar you would be at like 50~60% DC haha
Downside to higher pressure, the car won't idle too nicely on 98RON as the IPW is so low - but then again as Paul would say it's commuter fuel.
True. But then you could just size injectors correctly and not flog the ass out of the pumps.
Also depends on how much boost you want to play with - all a balancing act at the end of the day.
ID1700X if you baller 1550cc Bosch Motorsports if you're willing and 1250cc modified Bosch injectors if you're a bit strapped for cash lol
  • 1 year later...
Hi all , old thread I know but I need some info on the injectors that will be in next years Ford Mustang Shelby GT500 .
The engine is a 5.2L four cam supercharged V8 , named Predator , and surprisingly it will still have port fuel injection .
The largest current GT500 Shelby V8 injectors I know of are 630cc/~60lb Bosch EV14 mid length - 0280 158 298 .
I'm guessing that an around 750 Hp supercharged V8 would need 700 + cc injectors assuming they use one per cylinder .
They should be interesting because anything that can meet current emissions regs would have to have good atomisation which could be difficult to achieve in a biggish injector .
I have searched but not much info available that I could find .
Thanks in advance , cheers from Adrian .
  • 9 months later...
I never did get back on this , the 2020 Mustang Shelby GT500 injectors I believe are Bosch 0280 158 395 .
From memory they are rated at 650cc . Unfortunately they are a full length EV14 so not much use to us with OE RB25 type inlet manifolds .
Cheers A .
Old comment, but never saw this and seeing as the thread has been pumped I feel compelled to address it haha.  Running 3.5bar or so base fuel pressure is so far from flogging the ass out of pumps.   It makes way more sense running 3.5-4 bar base pressure on sensible sized injectors than running CNG based or other nugget things that a lot of people do to try and get sensible fuel flow for E85.    It's real common these days for factory cars even to run that range rail pressure, turbo Falcons all run 4bar base.
Most of these "Bosch 1700" etc injectors don't even match the claimed flow rate at 3bar differential pressure, the likes of ID1700x at 3.5bar will flow an extraordinary amount of power and if everything is specced correctly there will be 0 issues at that fuel pressure.
Edited by Lithium
    • 2 spots that my exhaust guy joined the 2 pipes together  Made a big difference. I'm now able to live with it. I can make it louder if I want by removing the HKS caps.
    • Hi all, considering clutch upgrade to support 1130 engine hp from 1650cc injectors on e50 at 85% duty cycle (1650 x (11.85/14.7) x 85%). Narrows down to these three as they can be converted to use gm 26 spline input shaft if I ever want to use transmission with that input shaft (orc1000f and r3c easy/cheap just change center hub; tr2cd pricier must change clutch discs). Pricing orc1000f similar to tr2cd, r3c about usd 200 pricier. Orc1000f triple plate 200mm. Tr2cd twin plate 215mm. R3c triple plate 215mm. Claimed max torque : orc 1000f 723 lbs ft; tr2cd 800 lbs ft; r3c 1100 lbs ft. Why orc1000f triple plate but claims lower max torque vs tr2cd twins? Is orc1000f underrated? Any info maxing out these clutches? Info on street/traffic driveability/pedal feel? Thank you for any info on them.
    • Some troubleshooting, connect up a timing light/gun with a proper ignition lead on coil 1. Hold the revs at 4~4500rpm and see if your timing is all over the shop, scattering off its tits. If so, there's a high chance your CAS is fked. But I read you have a Link ECU ready to go in, why not just skip all this and put that in - will make troubleshooting so much easier.
    • Misfires when the car is fully warm are generally attributed to the coils (and/or the igniter, on cars with a separate igniter). They can stop working properly when they get hot for a number of reasons. Either electric/electronic, or from thermal expansion opening up gaps and allowing HV leakage. Seeing as you have replaced the coils, that could/should rule them out. But I wouldn't always assume so. Were the coils genuine? Or is there a chance you have bought some counterfeit Chinesium shit? Then we're back onto loom connections. They can fail when warm/hot for the same reasons. Inspections, cleaning of contact surfaces, ensuring that terminals are fully inserted, etc etc, are all justified. The same (heat effects) holds true for the other electrics and their connectors. AFM & CAS, primarily. If you try that Chinesium AFM, drive it around on low load until it is properly hot, but do'nt give it more load than you have to, except when you need to see if it will still miss. I'm dead serious about the untrustworthiness of the calibration of those copy AFMs. Injectors are unlikely to get hot unless the fuel is coming back around hot. You could try squirting them with compressed air or freeze spray to cool them back down to see if they are maybe the cause.
    • Alright, all the plugs looks good. Noticed that it starts to get bad when the car is up to temp, that's when things starts to misfire hard. next to do is Injector cleaning and such. Got in touch with a shop to do work on the injectors next Monday also help on diagnosis.
