Hi Guys.
Hope I can get some help here. I have searched to try and see if I can get any info but could not get much.
If I could possibly get some info on the conversion I am considering doing please.
I currently have and Rb 25 Det engine. These are some of the Mods that were done.
Cylinder Head: Ported and Flowed
Cams cut 270
All rb 26 internals: Valves , Lifters , Retainers , Valve Springs etc
So the head is complete solid lifters solid cams not using vvt anymore.
Sub Assembly is stripped due to detonation: 1 piston in the ringlands , no 6 big end bearing spun.
So this is what I need help with please:7_sweat_smile:
A friend of mine offered me a rb 26 bottom end that I can fit the Rb 25 det Head too.
So some of the info that I have managed to get says it can be done. The Rb 26 uses 12 mm bolts.
But are there any other mods that need to be done in terms of water galleries and oil?
Can I use my rb 25 cometic head gasket of the block?
Or is this a straight fit?
Any input will be appreciated
Chev R
https://www.sau.com.au/forums/topic/473075-rb-25-det-head-on-rb-26-bottom-end/
Ok this comes from recent observation of what i was doing. I have a RB26 head and a Neo 25 Head. And a 26 Tomei headgasket.
On the RB25neo with VTC, the front intake side of the head has a hole for Coolant and another one for VTC, when i matched the 26 Headgasket to it both holes get mixed. As  the HG is the same as the rb26 block, if u use the RB26 block with the 25 head i think you would have to do something about its VTC oil feed as it will receive Coolant.
Do this, grab your head gasket, the block and the head. and try to match the HG on the Block, you will see what i mean, then try to imagine whats gonna happen when u mate both pieces, that should help you decide which headgasket to use.
  • 2 months later...
    • Very nice - I also have a 92 GTST and hardly see any others around these days
    • When I need something else to edit, I use Movavi. A friend who does video editing on a daily basis recommended me) it's an easy video cutter to use for beginners
    • I need to edit some videos for work but I'm not good at all this. Which video editor can you recommend?
    • I think you're really missing the point. The spec is just the minimum spec that the fuel has to meet. The additive packages can, and do, go above that minimum if the fuel brand feels they need/want to. And so you get BP Ultimate or Shell Ultra (or whatever they call it) making promises to clean your engine better than the standard stuff....simply because they do actually put better additive packages in there. They do not waste special sauce on the plebian fuel if they can avoid it. I didn't say "energy density". I just said "density". That's right, the specific gravity (if you want to use a really shit old imperial description for mass per unit volume). The density being higher indicates a number of things, from reduces oxygen content, to increased numbers of double bonds or cyclic components. That then just happens to flow on to the calorific value on a volume basis being correspondingly higher. The calorific value on a mass basis barely changes, because almost all hydrocarbon materials have a very similar CV per kg. But whatever - the end result is that you do get a bit more energy per litre, which helps to offset some of the sting of the massive price bump over 91. I can go you one better than "I used to work at a fuel station". I had uni lecturers who worked at the Pt Stanvac refinery (at the time they were lecturing, as industry specialist lecturers) who were quite candid about the business. And granted, that was 30+ years ago, and you might note that I have stated above that I think the industry has since collected together near the bottom (quite like ISPs, when you think about it). Oh, did I mention that I am quite literally a combustion engineer? I'm designing (well, actually, trying to avoid designing and trying to make the junior engineer do it) a heavy fuel oil firing system for a cement plant in fricking Iraq, this week. Last week it was natural gas fired this-that. The week before it was LPG fired anode furnaces for a copper smelter (well, the burners for them, not the actual furnaces, which are just big dumb steel). I'm kinda all over fuels.
    • Well my freshly rebuilt RB25DET Neo went bang 1000kms in, completely fried big end bearing in cylinder 1 so bad my engine seized. No knocking or oil pressure issue prior to this happening, all happened within less than a second. Had Nitto oil pump, 8L baffled sump, head drain, oil restrictors, the lot put in to prevent me spinning a bearing like i did to need the rebuild. Mechanic that looked after the works has no idea what caused it. Reckoned it may have been bearing clearance wrong in cylinder 1 we have no idea. Machinist who did the work reckoned it was something on the mechanic. Anyway thats between them, i had no part in it, just paid the money Curiosity question, does the oil system on RB’s go sump > oil pump > filter > around engine? If so, if you had a leak on an oil filter relocation plate, say sump > oil pump > filter > LEAK > around engine would this cause a low oil pressure reading if the sensors was before the filter?   TIA
