See if this can stir the pot.
BNR32 GTR 1990 (PAINTED WHITE, no idea when).
17psi (Garret 2860-5’s)
Full engine rebuild at EAS Performance
KM’s:  125,000 km’s on body, < 25,000km’s on Engine.
Price:  $45,000 Registered with RWC. Firm.
PM me if you’re genuine and financial. No test drives, until I have cash in pocket. I can drive you though!
This R32 GTR was purchased from JSA Imports in Melbourne/Preston over 10 years ago. I was the first to register this car in Australia when it had 87,000 kms on dash. There was slight amount of rust occurring within the inner drivers side rear guard when I went to purchase this car. Which I had them cut out rust and fixed professionally before purchasing it. I can see a slight amount of bubbling in paint from more rust in the same lower part of the guard 10 years later. Since owning this car there has been a lot of money spent on it. There has been no cheap parts put into this car. As I have purchased all the top of the range parts when rebuilding this motor. The motor was rebuilt by EAS Performance in Melbourne/Airport West, the engine machining and blue printing was down at Williamstown Engine Rebuilds. I have added three new electric 'Mirror Drift' gauges to the original cluster on the interior console, the original 'air vents' have fallen apart. I will arrange for the three new OEM vents to be replaced before purchase. Apart from that the interior is pretty good (2x small holes in drivers seat plus some passenger seat stains). Plus one small dint in bonnet.
Engine - full rebuild by EAS Performance
Arias Piston
Stock Rebuilt Head
Oil galleries filed down or bolts for better oil flow in bottom end also.
Eagle H-Beam Rods
ARP 2000 Head Bolts Stud Kit
ACL Race Series Engine Bearings (Big End/Main)
NISMO Racing Oil Baffle Plate
N1 NISMO Oil pump
N1 NISMO Water Pump
R34 JUN Crank Collar
Splitfire Coil Packs
Garret 2 x 2860 -5’s
Twin X-Force Split Dump Pipes
X-Force 'Varex' Electronic Cannon Muffler. 92db - 110db (3-stage remote control)
GTR Stock BOV's
Stainless Steel 3.0 Inch Exhuast System
Engineered NISMO Rebuild-able Twin Plate Button Clutch (Pop Riveted Clutch Pads).
JDM Smoked Side Indicators
Tinted Windows
This GTR is not quite finished as yet. But it is one clean R32 GTR if anyone is interested in finishing it.
Things to do on this car.
New ECU + Fuel System
CAM's and Gears
Suspension
Brakes + Wheels
Inter-cooler + Piping.
If interested in this car, contact me via email at,
[email protected]
Edited by WHITEBEAST
https://www.sau.com.au/forums/topic/473076-bnr32-gtr-painted-white/
    • Why not? Since mines been built, I've used low boost maybe 5 times.
    • Yeah, so widen your search to any Nissan speedo first, then go wider if needed. I will say though, that there is a better than even chance that what I said first will likely come into play. They quite possibly won't come apart without damage. I tried to disassemble a stepper gauge that I wanted to repair. There was no way that needle was coming off the spindle, and I could not see how the spindle would come out of the mechanism behind. Assembled once, never to be disassembled, was my conclusion. Could be the same on the R34 cluster. Failing that - take the cluster to a workshop that specialises in automotive instrument work. There's usually at least one in every Australian city. They'll either be able to do it for you for small cost, or tell you it can't be done. It might be that "it can't be done" unless you follow some arcane procedure, including trickiness to glue it back together or something, that only experienced techs know.
    • Well, given that I, an engineer, almost never bring out the torque wrench to tighten up chassis bolts, despite fully knowing the theory, and instead rely on feel, which I happen to know is exactly how the majority of mechanics do things, should tell you the level of actual peril that exists from not achieving exactly 88 Nm of torque. How about if I just say then that 88Nm is at the lower end of the correct wheel nut torque range? Everyone knows how to tighten a wheel nut, right? And almost no-one ever brings out the torque wrench for that task
    • Don't be ridiculous. "2-3 ugga duggas or one Oof. You have to use Oof on tie rods because you can't get an ugga dugga on there." Is not helping the guy at all.
    • I have done a lot of research before posting here and on gtruk forum. couldn't find anything. I have my gauges all part except the needle itself. the needle has a extremely small hole in the center, but the shaft going to the needle is extremely small and appears to have nothing to index it either. doesn't seem strong enough to simple pry or pull without damaging something. Already tried the old spoon trick on a extra triple meter I have from a gtt, but no luck. the center cap comes off easily but the hole in the meter face plate aren't big enough to get over the needle itself. figured this would be my best place to find someone who might have actually removed theirs. wonder if there is some type of small pin press tool to push the pin in while pulling the needle base off.
