See if this can stir the pot.
BNR32 GTR 1990 (PAINTED WHITE, no idea when).
17psi (Garret 2860-5’s)
Full engine rebuild at EAS Performance
KM’s:  125,000 km’s on body, < 25,000km’s on Engine.
Price:  $45,000 Registered with RWC. Firm.
PM me if you’re genuine and financial. No test drives, until I have cash in pocket. I can drive you though!
This R32 GTR was purchased from JSA Imports in Melbourne/Preston over 10 years ago. I was the first to register this car in Australia when it had 87,000 kms on dash. There was slight amount of rust occurring within the inner drivers side rear guard when I went to purchase this car. Which I had them cut out rust and fixed professionally before purchasing it. I can see a slight amount of bubbling in paint from more rust in the same lower part of the guard 10 years later. Since owning this car there has been a lot of money spent on it. There has been no cheap parts put into this car. As I have purchased all the top of the range parts when rebuilding this motor. The motor was rebuilt by EAS Performance in Melbourne/Airport West, the engine machining and blue printing was down at Williamstown Engine Rebuilds. I have added three new electric 'Mirror Drift' gauges to the original cluster on the interior console, the original 'air vents' have fallen apart. I will arrange for the three new OEM vents to be replaced before purchase. Apart from that the interior is pretty good (2x small holes in drivers seat plus some passenger seat stains). Plus one small dint in bonnet.
Engine - full rebuild by EAS Performance
Arias Piston
Stock Rebuilt Head
Oil galleries filed down or bolts for better oil flow in bottom end also.
Eagle H-Beam Rods
ARP 2000 Head Bolts Stud Kit
ACL Race Series Engine Bearings (Big End/Main)
NISMO Racing Oil Baffle Plate
N1 NISMO Oil pump
N1 NISMO Water Pump
R34 JUN Crank Collar
Splitfire Coil Packs
Garret 2 x 2860 -5’s
Twin X-Force Split Dump Pipes
X-Force 'Varex' Electronic Cannon Muffler. 92db - 110db (3-stage remote control)
GTR Stock BOV's
Stainless Steel 3.0 Inch Exhuast System
Engineered NISMO Rebuild-able Twin Plate Button Clutch (Pop Riveted Clutch Pads).
JDM Smoked Side Indicators
Tinted Windows
This GTR is not quite finished as yet. But it is one clean R32 GTR if anyone is interested in finishing it.
Things to do on this car.
New ECU + Fuel System
CAM's and Gears
Suspension
Brakes + Wheels
Inter-cooler + Piping.
If interested in this car, contact me via email at,
[email protected]
Edited by WHITEBEAST
https://www.sau.com.au/forums/topic/473076-bnr32-gtr-painted-white/
    • Sounds like it is rotational in the driveline. CV? Tailshaft CB? Also.....didn't you just pay to have that bit painted and put on the car?
    • Yeah, when I dialled my idle down, given how much time I spent idling at the lights in traffic on my daily commute, the effect on overall fuel consumption was absolutely noticeable.
    • Emissions, fuel consumption, heat, noise, etc. most likely.
    • For me at least the reason why it bothers me is because it's indicative of a deeper problem. And that will nag at me forever. Especially because I have tailpipe emissions testing + evap leak testing every 2 years.
    • WELP. I went to the track, and I suppose it went okay because any time you can drive home is okay. You may notice the car is not on the circuit in this picture. It was about 35C day out in Benalla which means the track was approximately the surface of the sun, probably. Good things, car did not overheat but it _was_ warmer than when I had done track days in similar heat before, I think, I'm not sure - I can't quite remember. Coolant got to ~105 via the ECU after 20-30 minutes of belting it in said heat. Oil got up to 145C in one instance which is pretty crazy due to oil cooler. Pressures were fine. I seem to remember this not getting quite so high before the vents. More HMMMM'ing to be done. On the subject of HMMM'ing, can anyone identify the sounds in the video below, you will know which ones I mean: https://www.youtube.com/watch?v=uj3BkI2cbTc I included some 'normal' sound as a reference for the first minute or so. The microphone in this instance was where the license plate is. It stopped working later in the day which is why my "best example of a lap video (not produced)" had internal audio - Isn't hearable from inside the car. I don't mean the chirping of the un-bedded/badly bedded track brakes which you can only hear while braking... Thoughts, brains trust?
