Big Brake Kit for S14 with R32 GTR rear
I had these made by Kido Racing (Taiwanese company) with plans to sell but never went ahead. These were never used or fitted. Made for my S14 with R32 GTR rear brakes, but may also fit R32/33 GTR.
  • Front: 8 piston calipers w/ temp sensors - 356mm full floating rotors.
  • Rear: 4 piston calipers - 330mm two piece rotor with integrated handbrake ring.
- Comes with braided lines for front and rear.
- Track pads supplied (most likely rubbish)
- Compatible Brake Pads:
  • AP Racing CP5070D51 - AP Racing CP3894D51
  • HAWK HB-121
  • HAWK HB-109
  • Ferodo FRP3076
  • PAGID 8018
- Digital gauge for front brake temp
Price: $3000
  • 1 month later...
On 2/21/2018 at 11:25 PM, oxford1327 said:
ok  that's fair enough, if sale falls through i would definitely like to come and look at them, and have a measure etc to see if they'd fit
Hi Danial,
Buyer did stuff me around and they are for sale again if you're still interested.
Thanks
David
Would love to but it's going to depend on how much it costs to get car repaired now as got hit and run by a turd on the freeway Friday, lucky I have a dash cam do hoping police will be able to chase them down. ?.
I'll be in touch when I can afford them, but if they are gone in the meantime so be it....
If possible, I'd like to come and measure up whether these will fit my rims either Saturday or Sunday, if that suits you? And if they will I can leave a cash deposit on the day to secure them.
Shoot me a text at 0417151262 if you don't want to discuss on here, I've had similar experience with scamming dirt bags while trying to sell my race bike in last few weeks.
No problem, will send you a text in the morning.
Yeah, can’t believe he (sorry Maria) won’t give up. Dumbass didn’t realise he texted me from the other number by accident the other week.
Dave
Both @I will and @Ozmaria have been using the same IP addresses.
They used the same IP when posting in this topic too.
Both are now banned.
EDIT: For those who read this and are confused - i have hidden the posts that led to the bannings.
Thanks Christian for acting on this proactively, was going to inform you about it also and pass on the details.
Dave
 Share
    • I am impressed with all this level of adjustment. I didn't expect all this possibility
    • Correct.  In the case of the 500kw dyno plot I showed you the car actually runs two boost control solenoids for boost control and a 5psi wastegate spring.  It allows me to control how much boost pressure is applied to both sides of the wastegate valve at any point and fairly accurately control boost target as a result. I've tuned it so that it's able to target anywhere from 5psi to 25psi depending on what's needed.  The target tables I've set up in that car are Gear vs RPM, so every gear has potential for a different boost (and torque) curve.   First and second gear have quite low boost targets, third gear actually has different target boost all the way through the rpm range as it's a stock RB25 gearbox - the boost targets have been chosen to maintain a peak of 600nm (what the owner has set as the maximum torque he's happy with putting through the stock 3rd gear) but it carries that to the rev limiter.   The boost curve to achieve that is something of a ramp up, then hold, then ramp up again and the power curve looks more like a flat line haha.
    • so you can decrease or increase the boost depending on the diet as you wish?     by acting on the wastegate?
    • That's torque and power, it's all from a single run.  The boost curve is "held back" from it's peak target in the 3500rpm to 5000rpm range from memory, so it ramps hard to something like 18psi then climbs more progressively to 23psi nearer 5000rpm.   It makes the torque (and power) ramp more "natural" and less hard on parts and traction, it doesn't feel artificially held back.
    • Here's the torque curves from the car I ramped boost up later in the rpm to allow a slightly wider useful power curve - the power curve is a bit weird shaped also thanks to the TVIS (or whatever they call it with the 4EFTE in this Starlet) which changes the volume of the intake manifold throughout the rpm range, but you can see that the green power curve actually holds later on with the extra boost... but looks almost more like the kind of thing you'd expect from a cam or exhaust change
