Hey all,
My catch can filters were filthy with crap bubbling out and dripping everywhere, so when I changed the oil I gave them a good clean.
Now that the filters aren't saturated in crap, there is quite a lot of vapour coming out of the filters.
It seems to smell kind of sweet, doesn't smell like exhaust gas or anything like that. I would say the amount lessens or stays the same with revs - it doesn't appear to get any worse.
Here are a couple of videos showing the vapour.
https://photos.app.goo.gl/pnYO6bEGi3dFsCHk1
Keen to know what people think!
Cheers,
Edited by Jazzadub
@Dose Pipe Sutututu Don't worn valve steam seals usually cause oil burn in exhaust?
How would it cause excessive vapour from the catch can? Oil leaking in to cylinder and then oil fumes passing rings in to crankcase?
Edited by Jazzadub
  • Haha 1
@Dose Pipe Sutututu Just checked my records and valve stem seals were done when the head was reconditioned about 7300kms ago?
Also, I don't think I am seeing any blue smoke out the exhaust. I think the only smoke out the exhaust is from fuel; when it's running rich for any reason, backfiring etc.
Nope, not that I am aware of. And I frequently check that the coolant system is topped up and bled correctly.
Why do you ask?
... I have to do that because there is a hairline crack in the coolant jacket on the passenger side of the block :(
Really really slow leak, but it's a massive pain because I run Evan's waterless coolant, and that shit's not cheap. Really need to figure out a permanent way to fix that ...
Edited by Jazzadub
Remove coolant.
Remove turbo piping.
Cover up turbos or remove them.
Use a multitool to remove paint and dirt. Do this properly!
Use JB-Weld super glue/metal.
Let it dry properly!
Job done
  • Thanks 1
Thanks, will have to get that sorted one day.
Anyone got any more ideas regarding the blow by?
Maybe it just needs more time running after the oil change or something?
www.turbofast.com.au/TurbochargerFactsAndMyths.html
This is a source to have absolute faith in.  Probably an issue with overall breather design.  Mechanical baffling in the cam covers, breather hose sizes, catch can internal design and volume, and breather filter size/number.
You see people running two cans in series sometimes, looking to deal with heavy breathing/smoking.
Hose routing/orientation is also a factor to avoid oil vapours condensing and pooling in dipped/low sections.
There is a bit of thought/effort to get this aspect right.
Thanks I will check that link.
It hasn't always done this, so I don't think it is a design issue. It's a RIPS catch can with two feeds from rear of rocker cover, and two drains back in to sump.
There is a 1.2mm oil feed restrictor in the head also.
But in essence you think the amount of vapour could be normal, it's just not being condensed back in to oil correctly?
Or potentially the turbo oil returns have become blocked or restricted?
Edited by Jazzadub
That would be my line of thinking.
Everyone has an idea, and in Interweb forum land we are all experts.  But all engines breathe.  And the pressure in the sump carries vapours.  Emissions-legal cars have the vapours going into the inlet to be burned, normally shows up with all that caked on oil/grease trail in the inlet.
So it takes a bit of trial and error to configure a catch can setup that doesn't puff smoky vapours.
Just because a catch can has a workshop's name on it, doesn't mean it will work perfectly (even if it's better than many others).
I doubt if the turbo drain has become restricted, but it wouldn't hurt to inspect and consider whether it's sized and routed as well as possible.  All factors can impact results, so have a look.
One thing I found with my 30DET over successive track seasons, is that the engine breathes.  I have implemented a number of modifications to the setup, and this has helped a LOT to get things satisfactory (not a smoky oily mess underbonnet when a run is finished anymore).  But familiarity with the car etc means it's being driven harder/faster, and I wipe a rag around the catch can outlet to clean any haze that's evident.
Thanks. I hope it is just normal breathing as the compression was tested recently.
The amount of vapour only really became noticable when I cleaned the catch can filters.
Do you think I should oil the filters? I have some K&N filter oil. Perhaps that would stop the oil vapour passing the filters and keep it in the catch longer so it can condense?
I might clean them again and give that a try..
I'd say nature will take its course, and they will be well oiled without using the K&N stuff.
I generally give mine a hit with degreaser after a couple of events, reduce the saturation levels (probably a pointer that my system isn't quite right either).
Ahh cool. I guess I'll see if it lessens over time.
Do you think the catch can itself could do with a clean? It doesn't have internal access but I have a lot of ethanol I could soak it in?
Not a fan of catch can air filters. If you have that much stuff coming out on a regular basis you need an in-line air/oil separator or a second catch can - pull the hoses off to see if its coming from the sump or the cam covers...and then route the (last) catch can into the turbo intake.
Just now, KiwiRS4T said:
Not a fan of catch can air filters. If you have that much stuff coming out on a regular basis you need an in-line air/oil separator or a second catch can - pull the hoses off to see if its coming from the sump or the cam covers...and then route the (last) catch can into the turbo intake. Worst case scenario - broken rings.
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
