Many of you know this car well enough already, but here's the full run down. for those that haven't followed the build.
Kilometres - 88-89ks
Power - 380rwkw/509rwhp on E85.
EXTERIOR
  • Z tune style gaurds (Bodyform, properly vented as per OEM, mesh inserts at guard exit)
  • Z tune style bonnet (JSAI)
  • Z tune style bumper (Bodyform, mesh inserts)
  • Mines style carbon mirrors
  • Nismo style skirts
  • Nismo style rear pods
  • 19x9.5 Rays TE37s with 275 rubber, plenty of tread.
  • Black wheel nuts.
  • FRP High spoiler stands.
  • 2pac black spoiler blade.
  • Nismo style B-pillar garnishes.
  • OEM V-spec front diffuser, 2pac gloss black.
  • Nismo smoked front and side indicators.
  • Tinted windows, 1 shade darker than legal.
  • Customised front number plate, trimmed border, rounded edges recessed into front bumper with nutserts and angled for airflow into the cooler. Cleared with Vic Roads and Vic Police.
  • LED parkers to match Xenon light colour.
  • LED replacement for rear number plate light.
INTERIOR
  • Nismo style front mats.
  • Nismo style drop sheet covers.
  • Factory GTR sill protectors.
  • Pioneer media player with remote (bluetooth handsfree etc).
  • Upgraded front and rear speakers (not fantastic in my opinion).
  • Nismo GT500 gearknob.
  • Nur pedals and foot rest.
  • Autowatch alarm.
  • V-spec sensors on MFD (Intake and Exhaust Gas Temp).
  • Nismo lighter (unusued, non smoker car)
  • LED interior dome and map lights.
  • Carbon rear view mirror cover.
  • Front seats/bolters in excellent condition.
  • Steering wheel excellent condition.
  • No hole rear speaker covers (often have holes due to compliance).
ENGINE AND PERFORMANCE MODS-
  • 2 piece Concept front rotors with standard Brembos.
  • DBA rear rotors with standard Brembos.
  • Ferodo Pads.
  • BC ER coilovers (external reservoir with individual damper and rebound adjustment).
  • Subframe collars.
  • Whiteline Rear swaybar.
  • K&N Pod Filters and Adapters.
  • JSAI Pod Filter Shield.
  • AFM Deletes with Aeroflow silicon joiners.
  • KTS Suction kit (modified to remove extra nipple and powder coated) with Aeroflow silicon joiners.
  • Twin turbo pipe mod, powder coated, new badge.
  • Garrett 2859R-9 turbos, newer style with better cages.
  • N1 cast manifolds.
  • Painted exhaust manifold shields.
  • HPI 3" dumps.
  • HPI 3.5" front pipe.
  • Custom 3.5" mandrel bent, v-band exhaust.
  • Magnaflow 3.5" midmuffler.
  • Apexi 3.5" N1 Evolution rear muffler.
  • Custom 3.5" Cat.
  • Adjustable Cam Gears, dialed for response.
  • BC Valve Springs
  • Kelford L182A Cams.
  • Bosch 1000cc E85 compatible Injectors (resister pack delete).
  • Baffled and plumbed catch can with Aeroflow 400 series hoses.
  • Walbro 460lph E85 compatible in tank pump, regulator removed.
  • Aeroflow Fuel Filter.
  • Blitz Alloy Radiator - New silcone hoses.
  • Brake Master Cylinder Stopper.
  • ATS Twin Plate Carbon Clutch.
  • Full length FRP radiator air diversion panel.
  • HKS Oil cooler kit.
  • Splitfire Coilpacks.
  • Plazmaman 76mm Pro Series Intercoole, raw finish, no logo, badge on top of core.
  • Haltech Platinum Pro (Full flex fuel tune, ECU unlocked).
  • Haltech Flex Sensor.
  • Haltech Oil Pressure Kit.
  • Haltech Wideband Kit.
  • Haltech 4bar Map Sensor
  • Haltech I/O Expander.
  • Haltech Mini Can Bus.
  • Nismo style Oil Cap.
  • ARP Headstuds (original headgasket still inplace and no issues).
  • Z Spec Coloured Fastener/Washer Kit.
  • Nismo engine mounts.
  • Nismo trans mount.
SERVICE/MAINTENANCE -
  • All new accessory belts.
  • New Timing belt.
  • New Tensioner/Idler.
  • New Cam Seals.
  • New Crank Seal.
  • New Balancer.
  • New Water Pump.
  • New Cabin air filter.
  • Recently replaced gearbox and transfer case fluid.
  • Fresh Castrol Super Dot 4 Brake Fluid
  • Engine oil barely 1000ks old.
  • Anything that has come off the car has had new gaskets when it went back on where applicable.
  • AC Serviced/Regassed.
ISSUES/BLEMISHES -
  • Few small stone chips in front bar/bonnet.
  • A few small scuffs/scratches along skirts/sills etc.
  • One noticable blemish under clear in passenger rear quarter.
  • One small tear/wear through in carpet right next to foot rest in driver side foot well.
  • One very small burn mark on driver side rear seat, appears to be from solder of rear speakers.
  • Rear antenna removed from car, but available. Radio reception not fantastic but I never use it.
  • Small wear mark on passenger side guard liner.
  • Blemish on cowl beneath windscreen.
  • Passenger side headlight had a plastic repair done on one tab, in white instead of black.
  • Chassis rails have minor indentation from jack stands, actual jacking points are very clean though.
SPARES/LEFTOVERS - (Original = came from this car)
  • Original cams.
  • Original cam gears.
  • Original valve springs.
  • Original shims.
  • Original fuel pump.
  • Original fuel pump regulator.
  • Original rubber intake pipes to turbos.
  • Original Balancer.
  • Original Engine Mounts.
  • Original Trans Mount.
  • Original Oil Cap.
  • Original stick on rear window Antenna.
  • Standard bolt on brake ducts for OEM R34 Front bar.
  • Standard Exhaust manifolds.
  • Standard Exhaust manifold shields.
  • Standard and brand new fuel filter.
  • Standard oil/coolant lines from hot side.
  • Compliance modified rear speaker covers (holes for child restraints).
  • Left over Z-Spec Black and Red coloured fasteners/washers + bolts that were replaced.
  • 2x -9 turbos, 1x mint condition (7000ks still has balance marks etc), 1x with damaged compressor wheel, but spins freely.
  • Genuine airbox, side port, snorkel with new foam.
  • Apexi Panel filter to suit airbox, done a few hundred k's max.
  • Greddy radiator diversion panel, painted black.
  • Generic oil filter relocation block plate with lines to add on to the HKS cooler kit, was gong to fit next service.
  • Random stickers from parts purchases if that's your thing.
  • There may be some other bits I've forgotten.
I would consider a few things as part payment, though I realise the likelihood of people having them is low.
  • CA18DET engine: Forged, stocked, spun bearing etc - priced accordingly.
  • Close ratio dog box with CA/SR bell housing.
  • A half decent dual axle car trailer, tilting/bagged, but low car friendly.
A few extra bits of info to assist.
  • Car comes with 2 keys, 1x Original GTR key, one genuine but generic Nissan key I had cut. Alarm only has 1 fob, but another can be still be purchased.
  • Not interested in any form of Crypto as payment.
  • No, I will not meet you half way to inspect it, I've tried to provide as much info as possible to assist on this front and can take more photos as needed.
  • Inspections welcome, but you will not be driving the car until it's clear that you're serious about buying.
  • Mechanical inspections welcome, if the mechanic is not known to me the car will be put in valet mode if driving it is necessary.
  • Contact details of tuner who did most of the bigger ticket mechanical jobs and tuned it are available.
  • I have a bit of doco to go with the car, receipts, pictures of the build, import/degreg papers etc.
  • No rush to sell so please do not waste either of our time with low ball offers.
  • Overall the car is in very good condition for a 17yr old vehicle and has been well looked after. It's lucky to have done 2000ks in 2 years, I simply do not have the time to enjoy it.
Located Australia - Albury/Wodonga, happy to assist with transport as required.
Album: https://photos.app.goo.gl/E7MZpPg9oQs5kZxn2
Price 100k ono
Edited by ActionDan
  • Like 1
  • Confused 1
https://www.sau.com.au/forums/topic/473108-r34-gt-r-z-tune-inspired-build/
Getting a lot of requests for videos, I assume given my distance from capital cities.
I've added 5 videos to the album and can take more as required.
I'll have the car out tonight for some professional photos, then not again for a while so any requests should be made quickly :)
Car is now on carsales as I begin to make a more conscious effort to sell it to pursue some other things.
Offers welcome.
Some new photos taken recently so I have something to frame and look at on those cold winter nights...
  • Like 6
Very appealing 34gtr.
Unfortunately I've spent not far off this on my build that comes knowhere near this.
You should sell it relatively easy given some of the other crazy asking prices I've seen.
Congrats on what you've created.
Thanks Paul,
It's not a cheap hobby and I hope the car represents good value, but the market will determine that.
I'm not expecting a quick sale, despite being happy to discuss offers.
See how we go :)
  • 4 weeks later...
  • 3 months later...
  • 1 month later...
    • Pic of Nos, turbo kit and sequential not loading. 404 not found
    • im sure mine stays in gear and wont shift unless i shift it? and for sure it wont go back to Auto mode if its put in manual mode? if i use paddles but its still in D then of course it goes back to auto mode. but yer if its in -+ and i use paddles it will not auto change gears what so ever and i have tried this. it will gear down if at a stop though which is kinda nice but goes back to 1st gear not D. i think it used to be like this with imports aswell i dunno if its really like it anymore like when i got my R33 it had alot of JDM options which local cars didnt have. Now local cars have kinda caught up even the lower models. but yer transfer rates and other things makes it almost on par.
    • Very decent bit of kit. Definitely black it out I reckon.
    • Because people who want that are buying euros. The people with the money to buy the aftermarket heads and blocks aren’t interested in efficiency or making -7 power, they’re making well over 1,000hp and pretty much only drive them at full throttle  best way to way make money is know your customer base and what they want and don’t spend money making things they don’t want.
    • It's not, but it does feel like a bit of a missed opportunity regardless. For example, what if the cylinder head was redesigned to fit a GDI fuel system? It's worth like two full points of compression ratio when looking at modern GDI turbo vs PFI turbo. I'm pretty reliably surprised at how much less turbo it takes to make similar power out of a modern engine vs something like an RB26. Something with roughly the same dimensions as a -7 on an S55 is making absolutely silly power numbers compared to an RB26. I know there's a ton of power loss from things like high tension rings, high viscosity oil, clutch fan, AWD standby loss, etc but it's something like 700 whp in an F80 M3 vs 400 whp in an R33 GTR. The stock TF035HL4W turbos in an F80 M3 are really rather dinky little things and that's enough to get 400 whp at 18 psi. This just seems unwise no? I thought the general approach is if you aren't knock limited the MFB50 should be held constant through the RPM range. So more timing with RPM, but less timing with more cylinder filling. A VE-based table should accordingly inverse the VE curve of the engine.
