The bulb above is the high beam 9011/HIR1 halogen bulb. The big bowl design has been superseded by Philip's replacement 9011. If you want, you can get the original bulb design with this Toyota Bulb: 90981-13066.
For the low beam, you twist that 'high voltage' plug off, then unclip it. It should tell you what the bulb is on the base (D2R).
Thankyou so much for the info, I still haven’t pulled the one out that you said was a d2r bulb cause it a pain and I have to take the bar off so I wanted to wait till I had the globes I needed, are they all the same as Long as they say d2r or is there something else I need to know when buying them like something specific for the car model.. sorry for the dumb questions..
D2R are all the same (it's a standard size, like H7, H4, T10, etc.)
I get my bulbs from powerbulbs, I find that standard replacements work perfectly fine.
https://www.powerbulbs.com/au/product/osram-xenarc-d2r-single
Aftermarket bulb is a lucky dip, so stick with OEM replacements (i.e. Philips or Osram).
No problem, happy to help. Just ignore the eBay/LED idiot crowd.
While I'm talking about eBay, there are tons of fake (read >90%) Philips and Osram bulbs on there. They are very (visually) good copies but their quality control are trash, so be careful. Which is why I buy from powerbulb, I know I'll get genuine and their prices are good (with frequent discount codes).
  • 2 months later...
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
