The bulb above is the high beam 9011/HIR1 halogen bulb. The big bowl design has been superseded by Philip's replacement 9011. If you want, you can get the original bulb design with this Toyota Bulb: 90981-13066.
For the low beam, you twist that 'high voltage' plug off, then unclip it. It should tell you what the bulb is on the base (D2R).
Thankyou so much for the info, I still haven’t pulled the one out that you said was a d2r bulb cause it a pain and I have to take the bar off so I wanted to wait till I had the globes I needed, are they all the same as Long as they say d2r or is there something else I need to know when buying them like something specific for the car model.. sorry for the dumb questions..
D2R are all the same (it's a standard size, like H7, H4, T10, etc.)
I get my bulbs from powerbulbs, I find that standard replacements work perfectly fine.
https://www.powerbulbs.com/au/product/osram-xenarc-d2r-single
Aftermarket bulb is a lucky dip, so stick with OEM replacements (i.e. Philips or Osram).
No problem, happy to help. Just ignore the eBay/LED idiot crowd.
While I'm talking about eBay, there are tons of fake (read >90%) Philips and Osram bulbs on there. They are very (visually) good copies but their quality control are trash, so be careful. Which is why I buy from powerbulb, I know I'll get genuine and their prices are good (with frequent discount codes).
  • 2 months later...
    • @soviet_merlin Thanks mate!  Nothing too major but will hold me up for a while. I've got lymphomas to get taken off the back of my neck and the middle of my spine which always conjures scary thoughts!  It sounds worse than it is. Yeah great, conjuring more rabbit hole deepening , just what I need! 🤣
    • I'd argue the F50 kit I got is very good value. For ~2k I got the calipers (refurbed condition), adapters, pads, brake lines, rotors, and top hats. I think you'd be pretty hard to get Evo/GTR/350z brembos + the additional hardware for similar money. Used market for a pair of front calipers alone I've seen tend to run anywhere from $1500-2000 depending on condition.    That said, something like a GTR or 350z brembo is a lot easier to adapt to the Silvia.
    • Is there a significant price difference between the Evo/gtr/350z brembos vs the F50? Looks amazing.
    • I was actually being a tightarse at the time LOL... My OCD is tickling me into running a 2nd 8AN Teflon hose all the way down and removing the 2x OEM hardlines. My other side of my brain is telling me to run 2x hardlines front to back (also acts as a fuel cooler, so win win).
    • As I mentioned in an earlier post, I had some trouble with the Silvia's brakes dragging back in 2023. I managed to sort it out then, but the same problem came back to bite me late last year. Just take a look at the picture – I had a feeling the handbrake was acting up again, and I was right. Anyway, I'd been wanting to upgrade to bigger brakes for a while. Not that the Silvia's brakes were bad, but it was more of a "want" than a "need", you know? It was funny, though – at the time, I couldn't find any Evo Brembos, 350Z Brembos, or GTR Brembos for a decent price (of course, tons of them popped up online after I already bought my kit!). I ended up going with an F50 Brembo kit, which came with adapters, brake lines, 330mm rotors, and top hats. The F50 Brembo caliper was used in a few other cars too, like the FPV. I also decided this was the perfect opportunity to ditch the Silvia's ridiculous rear brakes and that awful handbrake (some of you were definitely right about that!). I picked up some R33 calipers and all the necessary bits – rear drums, backing plates, and new hardware to refurbish the calipers. Of course, it wouldn't be a project without a few hiccups. Turns out the brake master cylinder was playing up and basically (to put it simply) keeping the brakes engaged. I had it overhauled, and after some adjustments, everything was working again. The whole process took a while, as you can imagine. To top it off, the front right wheel bearings were shot and needed replacing too. This is a rare occasion where I'm posting an update while it's all still fresh! These pictures were taken just this afternoon.
