So they have been kicking around for a year or two in some cars and looks like a few of us have taken the plunge and made a purchase so just wondering what information is out there.
6 speed sequential that fits inside the standard GTR 5 speed case and bolts straight in. Got a nice load cell and rotary position sensor so you can set up closed loop flat shifts with a decent ECU. Gear ratios seems very sensible and friendly at 2.706 / 1.894 / 1.471 / 1.184 / 1.000 / 0.812 but have no options. Big 26-spline input shaft so requires a new clutch and rated at over 1000hp. Fair bit cheaper than a Holinger (with all the extras you need), Albins (which needs to have floor cut) and around the same price as an OS88 but with a lot more tech.
Seems they have run into a few issues along the way but have been quickly fixed under warranty and new versions have been introduced to fix. Claims of 38ms shifts (probably more like 50ms) is still crazy fast if set up correctly.
Who is running one? How easy was the ECU set up for flat shift? Anyone keen to share some experience or settings?
Edited by SimonR32
https://www.sau.com.au/forums/topic/473151-ppg-6-speed-sequential-for-gtr/
  On 18/01/2018 at 10:09 AM, Griffin said:
How much are they? ( I've heard the saying re if you need to ask you can't afford).
How user friendly street wise are they?
Expand
All said and done (if you get them to assemble it which was $1,700 alone), it’s about $23,500. That includes supplying your own case, shipping from SA to Sydney.
Not cheap by any means.
  • Confused 1
  On 19/01/2018 at 12:56 AM, sneakey pete said:
Is that a drive away price?
eg clutch, wiring tuning ecu around it etc? Or just the cost of a completed box?
Expand
No clutch.
No installation.
No tuning.
You get that.
Expand
I swear they have just jumped in price on High-Octane website?
Expand
I bought mine when they dropped the price to $19,800. That doesn’t include the housing, shipping or assembly. It has gone back upto the “normal” price again.
  • Like 1
So they definitely (in my case anyway) don't bolt straight into stock housing. There is 3 places that need clearancing, 2 for the selector forks and 1 for 6th gear. In saying that, a die grinder and flapper wheel makes it reasonably easy and not too time consuming.
  • Like 2
  • Thanks 1
For some info on setup you could try b2r motorsports in Ingleburn nsw, they have a fairly big build r32gtr with the ppg in it. Set up very nicely with a link ecu. they ve spent a lot of time getting it right. And it works very well. B2R Motorsports fb page has some videos of it.
  • 4 weeks later...
    • Yeah, you are right. It seems easier and more reasonable to boost the engine. And as you said the blocks are very similar but the cylinder bores are different.
    • Sound logic, but in actuality way more illegal than just having the wrong pipe. Normally, doing something like that would be forgery. Meaning you may have certain documentation for vehicle parts, but the actual parts are different ones and you just assign them the numbers and badging from the documents. But nevermind that. Nonetheless, I AM curious if this pipe was ever made by any official manufacturer this way, because I honestly am not familiar with this pipe layout and shape. As I will be putting on the HKS Silent Hi Power once my exhaust gaskets arrive, as long as it sounds right I will just roll with this front pipe. I can always order the actual Mines part if I run into legal issues. It would be an unnecessary expense as there is lots of other problems I have on this car as of now.
    • So, weld a plate with the Mines logo laser cut into it, onto it. Instant Mines pipes, whether they were or weren't originally.
    • I don't know if the blocks are "the same". They will be very very similar. Obviously, either the bore or the stroke is going to be bigger on the 20. If the bore is bigger, then the 18 head is unlikely to fit properly. If the bore is the same, then you can almost certainly fit the CA18 head, but there migth be a few fun things you have to do to make water galleries (or other things) line up properly. Or... it could just be real easy. Is it worth the effort? Almost certainly not. You can make nearly as much power on a 2 valv ehead as you can on a 4 valve. There's not any "magic" in a 4 valve head.
    • Yes, me too!!!!  I need to find a something that has all the abbreviations for what these cars have LOL
