So they have been kicking around for a year or two in some cars and looks like a few of us have taken the plunge and made a purchase so just wondering what information is out there.
6 speed sequential that fits inside the standard GTR 5 speed case and bolts straight in. Got a nice load cell and rotary position sensor so you can set up closed loop flat shifts with a decent ECU. Gear ratios seems very sensible and friendly at 2.706 / 1.894 / 1.471 / 1.184 / 1.000 / 0.812 but have no options. Big 26-spline input shaft so requires a new clutch and rated at over 1000hp. Fair bit cheaper than a Holinger (with all the extras you need), Albins (which needs to have floor cut) and around the same price as an OS88 but with a lot more tech.
Seems they have run into a few issues along the way but have been quickly fixed under warranty and new versions have been introduced to fix. Claims of 38ms shifts (probably more like 50ms) is still crazy fast if set up correctly.
Who is running one? How easy was the ECU set up for flat shift? Anyone keen to share some experience or settings?
Edited by SimonR32
https://www.sau.com.au/forums/topic/473151-ppg-6-speed-sequential-for-gtr/
21 minutes ago, Griffin said:
How much are they? ( I've heard the saying re if you need to ask you can't afford).
How user friendly street wise are they?
All said and done (if you get them to assemble it which was $1,700 alone), it’s about $23,500. That includes supplying your own case, shipping from SA to Sydney.
Not cheap by any means.
  • Confused 1
1 hour ago, sneakey pete said:
Is that a drive away price?
eg clutch, wiring tuning ecu around it etc? Or just the cost of a completed box?
No clutch.
No installation.
No tuning.
You get that.
I swear they have just jumped in price on High-Octane website?
I bought mine when they dropped the price to $19,800. That doesn’t include the housing, shipping or assembly. It has gone back upto the “normal” price again.
  • Like 1
So they definitely (in my case anyway) don't bolt straight into stock housing. There is 3 places that need clearancing, 2 for the selector forks and 1 for 6th gear. In saying that, a die grinder and flapper wheel makes it reasonably easy and not too time consuming.
  • Like 2
  • Thanks 1
For some info on setup you could try b2r motorsports in Ingleburn nsw, they have a fairly big build r32gtr with the ppg in it. Set up very nicely with a link ecu. they ve spent a lot of time getting it right. And it works very well. B2R Motorsports fb page has some videos of it.
  • 4 weeks later...
    • Well, I'm tired. I'm tired because about 4PM yesterday, before today's appointment someone immediately bought my bumper. They couldn't get it any other day as they're on the way back to NSW. So I had to do that big GTR conversion I had been planning. Unfortunately, the information on SAU about what you need and how this is done is incomplete. So what should be a simple bolt on affair, yeah, it's not. Did you know if you use all GTR items the bonnet won't close? This little manuever sent me into about 1am the night before trying to dodge a way to get it closed. I will have to revisit this in the next few days  - or maybe not, I may let a body shop figure it out. It all needs to come up and my motivation to pull the bumper off is low. It also seems to hit things in the bay where the GTT bonnet didn't. Yes I used 100% new OEM GTR items. Today, I had the joy of driving to the dyno looking like this: Given I had roughed in the fuel and given sensible but pretty conservative timing, I didn't really bet on having the car drive out any real difference than when it drove in. Sadly due to a miscommunication and laptop fun and games (and almost bricking the dongle, prayers and firmware updates indeed), I ended up using HP Tuner credits to licence the car that was already licenced. So in the end my laptop was used. It turns out my butt dyno is still well calibrated after all this time. The 325kw was on 74% Ethanol, the 313kw line was on 98. The other line is the 'before' line which was 281kw. While the numbers are pretty low, they're pretty in line with what you'd expect. Even if US dynos bump the whole result up about 50KW, gaining 10-15% is similar gains.  The curve of the cam is pretty much spot on with what was discussed as well. All this said, it still feels bad to not see the number you secretly want to see. Even if the car drove great beforehand, and I knew pretty confidently the car would drive out much the same way it drove in due to the nature of a wellish dialled in LS1 not gaining much if anything at all from being tuned from where it was. As expected, the car isn't particularly sensitive to running it at anywhere between 12.0 and 13.0 - And the initial timing at 20deg and 12.0 made 308KW. So 3 degrees of timing, and leaning it out to 12.7 for 5kw, anything above stopped giving any benefit until E85 (which has an additional 2 deg as before). Car itself behaved entirely fine. I found out that 100C = 1.15V! IAT at about 7pm was 19C. I might mess with the bonnet mounting.. but given the REO NEEDS TO BE CHOPPED TO FIT A GTR BAR this is possibly something I may leave gathering (more) dust until it returns to paint jail.
    • It sounds farrrrrrr too cold at your place Duncan... Here I was thinking our 10 degrees overnight is getting cold...
    • oh yeah, reminded this morning....bin lids frozen shut too
    • In my case not, because of total reno. But yeah.
    • Did you use an electronic speedo drive? Does you speedometer read all the way to 180km?
