Hey guys,
I hope someone can help me. I'm in the US, and my R32 has been stuck at Nissan because my driver's side output shaft for my axle lacks a c-clamp, so the shaft ever so slightly comes out of my diff. My mechanic is having a hard time finding the right c-clamp to lock the output shaft into the diff. Do you know what compatible vehicles like a 300zx or S13 for instance have the same kind of output shaft that I can snag the correct c-clamp from? Here's a picture of my output shaft too for reference.
https://www.sau.com.au/forums/topic/473161-r32-gts-t-rear-diff-question/
Neither the Z32 nor the S13 have the same stuff.  The Z32 turbo is an R230 diff with big 6 stud flanges.  So will not be the same.  The S13 turbo is an R200 like the R32, but has 3x2 bolt flanges.  But I think that the internals parts of the output shafts are same same, so C clips from one should suit the other.
Thanks for the info. I believe I found the correct part number for the cir clip. Should be 39600F. It's used on various models including my GTS-T. Hopefully I'm right aha.
What diff centre is in it?  There aren't really any options other than the original stub axles for the original viscous diff centre.  For Nismo diff centres, they have their own stubs that come with them.  For most of the other aftermarket centres, they usually use the original stubs.
I wouldn't have expected that you could fit anything from an R230 into an R200.  The NA Z32s use an R200, no?  In which case their stubs will either be very similar to R32 (if using viscous centres) or otherwise they will be equal length like on NA R32s, just with the 5 bolts instead of the 3x2.
I will admit I'm not being really helpful here because I don't really know which bits are the same or not.  Just pointing out the possibilities.
No I really appreciate the response man. I have no idea which kind of 2-way I have on the car though. The car was imported to the US through a dealer that specializes in bringing in cars from Japan, so there's no way of knowing with diff is on the car at this point. But this is definitely a "stub" output shaft right?
OK, now you need to put up photos of the centre.  If it's a 2-way, then it could be any of the possible brands (Nismo, Cusco, Kaaz, etc etc).  But if it turns out to be a Nismo, then there's a good chance that you will have the Nismo stubs and they may well need a different circlip to the original ones.
The car is at the dealer on a lift right now, but I think what I really want to know is, can I daily the car without having a c clip for the right side flange? I don't drift, nor do I plan to. The car was obviously drifted/driven aggressively before it made it to the States, but I have no intentions of beating the car that way. Also, I drove the car as it was for 4 months before the technician at Nissan alerted me that I didn't have a c clip on the right side.
Given that after you take the circlips off you usually have a struggle to get the stubs out of the centre anyway.......
Nevertheless, if it is actually loose enough to move in-out on its own, then it won't be good for the spline at the other end to possibly be belting into the hub.
I'm just gonna deal with it. I wish I knew what kind of hardware I was running, but unfortunately I don't =l it drove fine before I took it to the dealer, so I'll just stay on top of irregularities from now on.
    • Yeh... literally every time i jump on a forum, see an instagram post or see an engine bay at a car show, i get an idea and add it to my 'to do' list. So what started off as, hey can u just make a couple of intake hard pipes because my dumbass bought the wrong apexi kit, blew out into a 2 week job including braided brake lines & custom bash kit for the front lip haha.  Getting Luke from A4E engineering to make a full custom exhaust with a controllable aes dump valve so i can actually switch between quiet and loud, because right now its just loud all day every day. Then after that go and get the tune redone flex e85 & 98 as i get bugger all milage from e85, makes going for longer drivers difficult
    • Car looks clean as. You ended up getting quite a bit done 😂  So what's the plan for the exhaust?
    • The only Neo rods that were any different to any other RB25 rods were the DET ones, and they were the same as RB26. Here is a Neo DET rod. O5U part number visible. Here is a post in a thread here on SAU with evidence from someone who has done this before. There are photos in the thread of normal RB25 rods.
    • Sure, but why assume that will be the case forever? And why assume you'll be able to do an oil change to swap back to a stock drain bolt before that happens? And does it even matter when I change the oil at fairly short intervals? Life can be funny sometimes and unexpected things can happen. Like breaking a collarbone so you can't do any work on your car for a few months but the oil change is due so you have to take it to somewhere and hope they don't do something stupid like stacking the new drain plug washer on top of the old one.
    • Do u know how to identify the rods are rb25 or neo ones? Can u look into the pics and tell me is they de or de neo ones. Its confusing becoz my motor has de neo head but block is 25de 75t, so really confusing me about rods, crank.
