Hi SAU,
Purchased an R33 last Oct, seller was generous enough to give me a bunch of spare parts. For sale are all the parts i'm sure I won't be needing/have no space for.
Any reasonable offer will be considered. Items located in SE subs Melbourne. Not willing to post interstate sorry.
A full set of Work Meister S2R 18x10 +15 (5x114.3), all wrapped in Bridgestone Potenza RE001 (265/35 R18 97W)
$1200
- The alloys do have scratches, and major scuffs as seen in the photos below
- Each comes with center caps, and air valve caps
- Two of the tires have ~5mm of tread left, other two have ~6mm.
20180120_130245.thumb.jpg.761b6dbebbeab38ba751e78f470df604.jpg20180120_130223.thumb.jpg.eedfabb4030f3dce666e4056f065117d.jpg20180120_130153.thumb.jpg.74bdfe3be0b5d0dce32a576cd00fb2be.jpg20180120_130145.thumb.jpg.7ff1acd196a847bc366f8ebc70efa48c.jpg20180120_130138.thumb.jpg.31713dc686b3ae988c03c5f81c151692.jpg20180120_130115.thumb.jpg.824a5dbeacd47662187415f03d08777c.jpg20180120_130316.thumb.jpg.531a9925ee70bc6ab6d9a6807e7cccd3.jpg
A full set of Bilstein Coilovers
-$400, or $100 each.
- I'm not too knowledgeable on coilovers
- Boots seem to be torn
- Used to be on an R33 GT-R
20180120_130412.thumb.jpg.e35a73b94bc299895fc97962e2c23ae9.jpg20180120_130356.thumb.jpg.cc7b524fa4aff86e6581b86ac96288f7.jpg20180120_130342.thumb.jpg.66277225a60e970055ada270ebc150f4.jpg20180120_130339.thumb.jpg.dcbaa6bd52eef7949ee4d3bafd3ef0c4.jpg20180120_130330.thumb.jpg.a895e87763224eaa527d049d0e45a623.jpg20180120_130420.thumb.jpg.787fec54bb07452e3a3a0e00de930181.jpg
BCNR33 Interior Trim
-$50 each
- Each piece does have scratches and scuffs, refer to photos
- Gear stick surround with ash tray
- Steering wheel bracket cover
20180120_131049.thumb.jpg.7bad724a98278f9d5693138fbf83b6af.jpg20180120_131044.thumb.jpg.1e0b44cd3c550ed575b764fdb5e67c39.jpg20180120_131036.thumb.jpg.82cbd687034111a1a12c812d302003b8.jpg
  • 3 weeks later...
  • 1 month later...
  • 1 month later...
    • Getting Dangerously close to being ready to go back in the car. Rockers in with clearance castings now (and a quick check with the USA for the torque settings for the larger custom bolts) Covers and ported FAST Manifold sitting on there. Not fully tightened down as there's some clearancing required for the water pump with the earlier LS1 water pump styles. Example of the clearancing needing to be done: The body has to be ground a little but I'm struggling finding an actual piece of it. The later variant of water pump resolves the issue as the manifold was designed around it. It only came on the VZ LS1 in Australia, it got a different pulley for Gen4 motors. (it also costs $450... vs... $0).
    • https://files.fm/f/5atwkuvcjd
    • Doing some height adjustment on front suspension on a v35 and noticed this. The passenger side looks correct. So wondering what's happened to the drivers side?
    • Oh...I have the electric mirrors as well iirc ...they're in the same state as just about every other R31 door mirrors, with the 3 plastic screw towers broken/cracked in the plastic molding. All the interior is 'dry', so the mirror switches etc likely all work fine. Some pics below of the trimmer pieces ~ looks to me like previous owner, painted chrome finished trims with black paint ...ergo, the chrome underneath is likely a-ok... ...starts to look yukky posting stuff like this, how much did it cost in fuel on your last sortie up this way?...me just thinking aloud, borrow someone else's 4cyl to cut costs, come do your own pick'n'pull like before to save me some bother...hehe.. but whatever, I'll just earmark bits I know you want, because the way this is all panning out, I'll be able to retire the R31 from daily duty at long last, replacing it with a Subaru wagon I'm lining up in the wings...ergo, my attitude towards the donor pinny shell is starting to wane a bit, and I'm more than happy to help you out there... Like you say though, no rush...and I'll guarantee we won't be moving too far from this locale at any rate 😎
    • Cool, I’m just down Sydney today. Not much time to get online.
