Hi All,
Clearing out the garage and found a few things i'm unlikely to have a use for.
Trust/Grex Oil cooler. Sandwich type with thermostat. Suit R32 GTR and mounts the core in front of the AC condenser. $700
R32 Cusco front and rear strut Braces. $80 each
HKS pods suit stock afm's $50
R32 GTSt LH Tail light $50
2 boxes of GTR junk, stock exhaust manifolds, heat shields, intake resonator, twin turbo pipe (missing badge), bunch of oil and water lines, overflow bottle $free
Stock R32/S13 suspension arms, pretty sure i have 2 sets of all the rear arms, $20 per arm
R32 GTR steering wheel, pretty rough, has the GTR horn button $50
S14 diff, pretty sure it's a manual 3.9ish ratio $50
S13/14 drive shafts 3x2 bolt type $50 a pair.
Prefer local pick up but i can ship at buyers expense.
Contact via pm.
3 hours ago, hotz said:
I am interested in the gtr steering wheel.  Would u pls send me a photo of it. Thanks.
I'll grab one tonight
1 hour ago, iruvyouskyrine said:
Is the diff ABS?
I think so, will check and get back to you
4 hours ago, iruvyouskyrine said:
Is the diff ABS?
It's abs, but unfortunately looks like an auto 3.7...my mistake.
    • Honestly, for a daily I would gladly rock a Camry. The more disposable the better. People drive horribly out here and road conditions are awful.
    • Verify it's going into each of the 4 gears in normal acceleration, make sure the torque converter locks up over ~65-70 kph or so at low throttle opening. If you ease into the throttle at those speeds eventually you should get a "gear" between 3rd unlocked and 4th locked. It should downshift eventually if you floor it at 65 kph too. Get some Matic D ATF and drain the pan, check for signs of sadness in fluid and drain plug magnet. Top off to the correct level afterwards. If the transmission is worth saving you can drop the pan on a second drain and change the filter while you're at it. These are not complicated transmissions, at least compared to modern stuff.
    • A seat I find stupidly comfortable to sit in is the one in a friend's Merc Race Car. It even has the huge wings that wrap around your head. Best ever. Only issue is climbing through his scaffolding he put up in the doorway of the car... Ha ha ha. I sat in that seat for a couple of hours doing wiring. Another stupid comfortable seat I find, especially if my back is aching, is my OMP fixed back bucket seat too. I'll just sit on it when I'm exhausted in the garage sometimes to relax!
    • I just got off the phone with Dean from Vosta in Brisbane. They are the ones that do the replica seats and they have a shop full of seats for my to try out. Lovely guy.  I haven't decided whether to go genuine or replicas, I'm leaning towards Genuine at this point but who knows.  Also thinking the STRADIAs are the way to go VS the GIAS since they have a lower hip edge and would be easier to get into. Don't really like the idea of arm rests on the models to the right of this diagram either, maybe they can be removed?
    • From my own first hand experience, keeping power for a fun Street able skyline down at a responsive low 200 wheel KW, is the best. It makes it super drive able through the twisties, you're not just smashing mass wheel spin, or only able to open the throttle for a split second before being at absurd speeds. That said, plenty of people like being morons at more than double the speed limit on public roads and hence are happy with 600whp and seeing 200kmh fly up frequently and fast. Also, at that low 200, a GTR can still do a decent quarter mile, and with a bit of fancy  clutch work (foot, not the parts) can still beat many many cars in a traffic light gp, even in the wet.
