  • 4 months later...
I like setting easy goals because then it makes you feel good when you complete them. For my brief time back in NZ I decided I needed to get the car running with the triple carbs as when I left for Aus I had just got it running but it wouldn't idle and was generally not going well.
Since buying the TA22 in Aus which also has Mikunis on it I've learnt quite a bit about tuning them and setting them up which I've been able to transfer to the Skyline. So when I had a bit of spare time I started by checking the pilot jet settings which were waaaay off. No wonder it didn't run well. Fixed those up, cranked it over for a while to get the gas to go through (mechanical fuel pump) and with some dodgy choke opening and throttle fiddling the car started.
Took it for a burn up an down the road and considering I spent only a couple of minutes with synchrometer it works really well. Idle is a little high at around 12-1400 at the moment but it sounds good when the carbs are on song !
One thing I haven't checked is the timing so I've purchased a timing light to do that sometime in near future.
Aaanyway novel over, here's some photos of stuff.
Another one of the tasks I wanted to do is install a choke cable (or starter wire) for the triples. The one that was for the OEM single wasn't long enough and as I found out it anyway the previous owner just used one which was for a twin carb setup and cut one of the wires off! Mine is kind of janky and sort of works but it's not really that good. Maybe not required now that I've sorted out the basic jetting but it's something. Mainly has issues on the right side where it goes into that first holder. Needs a better mount somehow.
So being that I just took the car out for it's maiden voyage on the triples there was of course teething issues. One of them involves this pipe here. The brakes worked pretty much as well as they did before (to my knowledge) however the brake pedal was pulsating kind of with the motor. I'm informed this hose should have a one way valve in it so have now purchased one and should be here next week.
And a parting shot for your time. Also a quick walkaround if you're on Instagram - https://www.instagram.com/p/BkqjBL3gbW7
  • Like 1
Well I had to take my big brakes setup off my Crown (6 pot 380/4 pot 356) so I thought I'd upgrade the Hako ones..
After a little bit of custom modification to the dust shield or whatever it is this happened....
That's an 80s Hilux (reproduction) 4 pot caliper. These fit on without any modications whatsoever, exact same bolt holes and fit around the disc fine. There's also one advantage of having the brake disc mount behind the hub.. miles of clearance!
Thinking I'll probably need to get custom lines made up to match the new to the old but otherwise, success. So a decent up grade from almost 50 year old twin pots to 4 pots.
Also I plan to just remove that heat shield thing from the hub anyway or cut it off properly when I finalise the install on these so it won't be all super cutty.
    • It was roughly 3.5 hours.    car went in around 11:00 and I was done around 2:30 He did the initial runs, install the BC and then Nistune install and tune.  The best part was sitting in the lobby and hearing the skyline on full throttle at the dyno 😂😂
    • Glad it all went smooth. How long did the tuning process take?
    • Yeah that was kind of the same feedback my tuner gave me.  the boost tee is until I can sort out my plan for the electronic boost controller and what I’d get, where I’d mount the dash etc.  I’m happy with this until I can figure it out. Not a big fan of the A-pillar gauges. I’d like to get a clean install of the boost gauge - something digital like GFB.  Something like that might fit neatly where the ashtray is and look clean. I feel like replacing the OEM triple gauge is a bit extreme for a weekender like my skyline. And it’s not making crazy power to need all the additional sensors/gauges.
    • I'm about to swap my box to Tremec T56 Magnum F & initially thinking of re-using my DCS twin plate (can get it re centred for the bigger spline) but it's been called out the box will be noisy (rattle) as the clutch is unsprung.  So I'm doing as much research as possible. I'm not so worried about holding the power as I'll go the track version which on paper will hold the maybe 1000hp I make. It's the longevity I worry about. DCS told me they don't use a sprung centre as it's just something that can break. The uni clutch has a very complicated sprung centre. Any one had or heard about any issues with it failing? Thanks in advance.
    • Auto is at least 10% (from my real, actual experience with different torque converters and manual on the same setup) ~185rwkw at 11.6psi (peak!) is entirely what one would expect without a FMIC or anything else on the intake, it does bleed off towards the higher RPM so it's what, 9psi there? Note: There is nothing that can be done about this with a manual boost tee. If you want to hold it steady and gain more top end, well - You will need electronic boost control.....
