Got some R33 parts for sale... Located in Canberra.
NISMO R33 RB25DET 3" Front Exhaust Pipe. Comes with Dump Pipe and O2 Sensor - $150
Series 1 R33 4 Door Rear Tail Lights. Excellent condition, not a mark on them - $300 (pair)
R33 Polished Wiper Arms - $30
Have got a few more R33 4 door parts which I'll add soon, so watch this space...
Will ship at buyers expense. Contact me through here or msg.
Cheers, Luke. :)
Edited by Frink
Update info
Finally got around to digging up the rest of the parts...
So, also for sale:
set of R34 shocks and springs. shocks in good condition, no leaks. springs are Lovell Sports Rider and are quite firm. Good legal ride height. the springs will also fit onto a set of r33 shocks. $80
set of r33 sedan door cards. fronts not in good condition. rears are much better, but not perfect. $80 the lot
OEM Navan r33 sedan rear wing. good condition. paint starting to fade. brake light intact. $130
Sard fuel pressure reg. only used for short amount of time. $100
Greddy BOV. good condition. only used for 6 months or so. $100
Prices negotiable. Cheers, Luke.
Edited by Frink
    • Before you blow your car up, have you checked you've made all the correct modifications to the wiring if you're still using the RB20DE loom?   Some things to look at: The pin used for the map sensor on the RB25DET, is the same pin used on the RB20DE for the Ring Gear Crankshaft Position Sensor, no idea what you've got it plugged into now. The turbo pressure control valve solenoid you're talking about on the RB25DET, the same pin is used for the Variable Air Intake Control Valve on the RB20DE.   The factory manual has the wiring pinouts in it for you to check everything. It also has the diagnostics process to read codes out. In addition, there's a great table that shows what sensors and what actuators not functioning will relate to which signals. And Nissan confirm the as everyone else has from experience, the Solenoid being disconnected won't cause a fuel cut. However, the turbo pressure sensor being missing / wrong, WILL cause a fuel cut. https://www.nicoclub.com/service-manual?fsm=Skyline%2FR34-Workshop-Manual-English.pdf
    • I've been hunting info on the G Series II - this is best I have found so far(Link below). Still waiting on the G35-1150 comp map, kind of very keen   So how do we go about getting precision on that little table of yours ?   https://turbosbytm.com/sites/default/files/product/technical-info/Garrett-G-Series-II-Product_Flyer 25 30 35_1.pdf
    • yeah I get ~0.6L per session into the catch can. very ethanoly. It ends up overflowing out the breather of the catch can on circuit days too even with a 2.3L capacity catch can and I only drain out ~0.6L max. So every session I have to come in and drain the catch can, which is a hassle. So this is me cracking the shits and doing everything I can without removing the motor (back of head sump drain/breather and oil restrictors off the table). plans short term are: full length splash plates remove oem cam cover baffle add foam and reinstall at -10 or -12 AN fittings to the side of the cam covers down to the sump (luckily I already have fittings in the sump) Yes the ~340,000km unopened motor is probably not helping things
    • I'd use any fuel safe foam....mine went in 15 years and 15 rebuilds ago, still getting reused I'd have to say I don't understand swapping to studs to fit a particular baffle unless you are having a massive blowby issue, and even if you are addressing crankcase not head breathing is probably the next step.
    • BTW, the reason I came in here to "update" this list was that the Garrett G Series II range have been released and I've updated the list with their flow details if you're curious to check how they fit with previous Garretts and other brands The G-Series II G35 990 looks like a banger...
