I’m fitting an rb25 turbo on my RB20 and am wondering what the best sounding outlet pipe is. I’ve looked at the tomei, but I’m not really looking at spending 300 usd for an outlet pipe. What else do you guys think? Also looking at downpipes aswell.
Outlet pipes ( to intercooler?) don't make a sound. Find someone with an RB25DET and copy their set up with stock (second hand) gear. Yes get a three inch downpipe.
53 minutes ago, iruvyouskyrine said:
Oh you americans.
Doesn't matter what 'outlet pipe' you use, it's attached to an RB20 so going to sound good.
too right!
  • 9 months later...
On 1/31/2018 at 10:00 PM, niZmO_Man said:
But ...
That's a R31house takoashi MAX manifold.... they are by far the nicest looking manifold for an RB and now long discontinued for the new version which is a direct replica of the gts-r manifold ?
But yeah anyways...I have a gtsr manifold that's unfortunately been re-flanged and had a gate welded to it then removed and repaired at some stage....Cost me a packet too.
Would looks amazing if it wasn't that terrible chrome colour ?
Sidenote: My manifold sounds absolutely amazing but i cannot provide evidence as a truck crashed into the car the second day of driving it and now looking like its going to be written off :(
  • Sad 2
Sidenote: My manifold sounds absolutely amazing but i cannot provide evidence as a truck crashed into the car the second day of driving it and now looking like its going to be written off [emoji20]
They're made from stainless just like the original gts-r takoashi and would discolour almost instantly with the first few drives and heat cycles. There's actually a picture somewhere I saw last week on the R31house owners blog of the ver3 test manifold after it was test fitted and ran for first time on the his R31 and it's turned a nice heat treated purple/brown/blue - ish colour...
  • 2 months later...
  • 3 weeks later...
Long time since I have been on SAU but I might be buying a new skyline.  Definitely  keen on a GTS-R manifold this time. The R31house takoashis are amazing.
I noticed a fabricator in Australia is now making replica R31house takoashi style manifolds. The business is "speedtek". They have stainless versions on their Facebook page, and a steampipe version on  ebay.
Does anyone here know anything about these, and if they sound the same as the original GTS-R / R31house variants. The runner length and merge collector style is essential to the sound these manifolds make, so hopefully speedtek have those lengths correct. The stainless versions look perfect to me.
The good thing about a gts-r or takoashi  manifold is they  sound completely  different to any other turbo manifold, including equal length 6boost style ones...
Some pics of these speedtek ones I have found are attached.
Here's my favourite video of a GTS-R manifolded car. Rb20, itbs, gtsr mani, pure madness. This guys youtube account is pure exhaust porn for anyone interested.
https://www.youtube.com/watch?v=bhw8Tpa78wg
The manifolds look decent but speedtek don't have a good rep for various reasons. Some to do with quality and some to do with the dodgey guy that runs it. Can't remember the details about him right now but im sure some Google investigating will uncover it.
  • Like 1
Yep, some googling has revealed some pretty unsavoury stuff. Surely they  can't be that hard to make though? It's strange no one else has ever attempted them (excl  R31house).
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
