WTS: 570cc Nissan injectors & O-rings
Factory vr38dett R35 GTR Injectors, however they have many other applications.
They came out of my R34 GTT rb25det neo and were in working order. They can be installed on a factory fuel rail.
The seals and o-rings were damaged on the way out, but I'm including genuine nissan upper and lower o-rings for a rebuild / service.
One Injector had it's end cap damaged as pictured, will need to be fixed.
I believe they are a direct fit for other nissans such as Z33, Z34, V35, V36 and Stageas.
Located Newcastle, NSW
Can post
$200 neg20180130_200326.jpg20180130_200337.jpg20180130_200407.jpg20180130_200430.jpg20180130_200446.jpg
https://www.sau.com.au/forums/topic/473241-more-r34-stuff/
WTS: R34 GTT factory Diff Centre series 1
Was working before removal, could use a re-shim/ service etc etc.
Removed because I upgraded to a Nismo 1.5 way.
Pickup preferred as it is heavy
$100 neg20180130_193105.jpg20180130_193110.jpg20180130_193116.jpg20180130_193121.jpg20180130_193123.jpg20180130_193125.jpg
https://www.sau.com.au/forums/topic/473241-more-r34-stuff/#findComment-7866586
Should've put it all on one post. My bad
- R34 Gtt front and rear shocks AND pedders lowered springs.
Front shocks are Koni adjustables and probably didn't even go 5000km before I decided to go with coilovers,
Rear shocks are Bilsteins and have no leaks. FORK TYPE!! If you have hicas these will fit.
Dust boots on all shocks are shot and need replacing.
$200 neg
- R34 GTT rb25det NEO factory fuel injectors.
Purchased in working condition from shamrock spares but were never installed. Missing the upper o-rings, but could probably use a service before use anyway.
$60
Located Newcastle NSW
Can post the smaller stuff.20180130_185758.jpg20180130_185805.jpg20180130_185815.jpg20180130_185829.jpg20180130_185836.jpg20180130_185851.jpg20180130_185901.jpg20180130_185910.jpg
  • Like 1
https://www.sau.com.au/forums/topic/473241-more-r34-stuff/#findComment-7866588
    • Personal experience. Those f**kers burn. And are actually a PITA to put out. Next time I walk down the back, I'll snap a photo of what the inside of the bonnet looks like when that thing ignites. PS, powder fire extinguishers are useless on that stuff too as it's fibrous and when it ignites, it starts to pull apart. And you end up just blowing powder through a sieve effectively.   Like the big thing is, if it's fire resistant, it's job is to stop what burning? The METAL above it? It's just to try keep heat off the bonnet paint work.
    • Oh man, sorry, $60.00000000... 😛
    • That's more or less what he meant. What it really means is that you do not have to go full crazy on the build. Don't need the best oil pump, expensive rods & pistons, big cams, etc. You can upgrade whatever you want instead of using stock level items, but you don't have to. Having said that - any time an RB is opened up, if anything is getting replaced, I think the opportunity should be taken to do all the sensible upgrades. Pistons, rods, pump, etc.
    • February update 🙂 We managed to get the very last 1/18th "Extra Scale" cars stock available from bookstores in Kyoto. These are actually the last ones and will not be restocked again! Hachette Collections Japan have not decided on a release date for these or other models in the series, so for the time being these are all there are available new.  These are showing up on Yahoo auctions at inflated prices already (especially the Celica and NSX) so get yours now at a very reasonable price before they disappear! Stock quantities: NA1 Honda NSX - 1 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1990-na1-honda-nsx 1973 Toyota Celica LB 2000GT - 2 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1973-toyota-celica-lb-2000gt 1968 Mazda Cosmo Sport - 2 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1968-mazda-cosmo-sport 1970 KPGC10 Nissan Skyline 2000GT-R - 2 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1970-kpgc10-nissan-skyline-2000gt-r
    • When you say basic rebuild, you mean an oem rebuild?
