Moonlight Racing is proud and excited to bring you Diamond Design! This is a new brand launched by us for big brake kits and accessories. Inspired by what we saw overseas and the lack of customisable kits in Ne Zealand we have worked hard to bring something affordable and stylish to the market.
By having 15 awesome colours to choose from to colour both the rotor hat and the calipers means you will be able to have a unique set of high performance brakes to match your style. These are available from small 4 pots right up to massive 8 pots and our kits come with everything you need to simply bolt on install and drive.
14639874_194094607701005_483897889276845
This set is fitted to a high power R32 GT-R. 8 Pot 380mm!
Have just done this black on black 330mm 6 pot set for a DC2 race car. Customer is very happy with the first outing after Honda Cup this last weekend.
15227886_10211074285802755_1163071267_n.
He is running Endless pads, no fade, no overheat, no warp!
This set went to @Leroy Peterson , he likes purple!
Definitely had a few rad things through recently!
This E30 had it's first outing over the weekend with our 4 pot setup installed.
Brent with our 6 pot option getting prepared for the upcoming season!
This Evo 6 with our first set to go through cert, also sporting 6 pot up front.
These whoppers for my own Crown, 6 pot 380mm up front, 4 pot 356 down back.
All positive feedback!
Because safety is important we've had the brake lines and brackets tested independently here in New Zealand and they pass with flying colours.
So if you're looking for something that is largely looked over to stand out from the rest get in touch with us. We have kits starting from $1999 shipped!
Go and like our Facebook page as well - https://www.facebook.com/Diamonddesignnz for news and product images.
Website: www.diamonddesign.net.nz
  • Like 1
https://www.sau.com.au/forums/topic/473243-diamond-design-big-brake-kits/
    • GTSBoy on your suggestion on another thread I had a look at those injectors and ended up getting them because of the quality.  Got the expensive ones.
    • Hey guys been looking everywhere to try and find the correct gtr hood latch support part number but only found the first half and when I search with that number it sends me to an r34. The first part I found was 62515. If anyone could help me with the rest then I’d really appreciate it. Or if there’s some alternative hood latch support that would work even better cause I can’t find any for sale. (Searched on upgarage, partsouq,buyee,rhdjapan)
    • If you've only done the upper control arms on the rear, AND you have changed their length (by more than about 1mm) to set the camber you want, then you will definitely need/want to install traction arms also. Adjusting the camber arms on their own WILL introduce bump steer and make the car unpleasant to drive. Most owners have no idea that their car could behave infinitely better than what they put up with. I'm not entirely sure what the Stageas need, but I am thinking that unless you have massive front spring rates and pretty soft rear springs, you have waaaay too much rear bar. Oversteer city, in my estimation. Combined with possible excessive bump steer from maladjusted arms, that could be a recipe for nastiness. ATR43SS2 is not a highflow. It is an outright replacement turbo. It's a little bit bigger than the largest highflow profile that Tao does. Probably a solid 300rwkW turbo where the bigger highflows will be about 30-40rwkW less. Nevertheless, we're only talking about ~300 rwkW, which is well within the abilities of the stock ECu to run with a Nistune on board. I would do so without hesitation - and I will be doing so when I get my finger out and actually get the injectors and AFM installed. But, if you would prefer to drop a whole lot more money on the ECU side, then I suspect you're looking at Haltech. The Haltech fanbois here will all spout on about all the available engine protection you can have, that you can't have with the Nistune option. And they're right. But it doesn't really come for free either. You will spend more money on extra sensors and the like, plus the work to install them. If the engine was built and therefore represented a big investment to protect, then I'd say definitely do it. If you view the current (and forever into the future) shortage of replacement engines as something to prompt similar protection, then also, do it. If you see a destroyed RB25 as an opportunity to put in a Mercedes or other V12 (like I kinda do)... then your perception of the risk/reward might differ. These are good injectors. You can also get a "better" set of the same with more flow matching, for more $$. 1000cc is where you will want to be. You will need an R35 AFM and adapter tube if you want to stay with Nistuned stock ECU. Otherwise, if going Haltech, you can ignore. As for intercooler. Just about anything will do. You're only talking about ~300rwkW. Just put a big core in there. Be aware that return flows do add significant pressure drop and will cost power and will make the turbo work harder to achieve the same goals. If you can manage a proper crossflow, do it. I'm keeping my very good return flow because I'm only expecting to be in the ~250rwkW range, and will live with whatever outcome I get.
    • I have a heap that i have collected if you want some authentic ones still. Pm me if your interested!
