Apologies, I know there are probably loads of threads about this. A search brings up a stack of results but nothing that specifically answering my question.
My stock turbo popped on my R33 GTST (I think its series 1.5). There is slight shaft play and the impeller is touching the housing.
Question is, should I recon it and have the ceramic wheel replaced with a metal one or change the turbo?
My end goal is 400-450hp. The plan was to do injectors, MAF etc. before the turbo but i have to change that around now.
If I change the turbo, what are the suggestions for something which will be a straight swop or close to it?
The car is basically stock with just a milteck exhaust.
https://www.sau.com.au/forums/topic/473250-suggested-turbo-on-a-stock-rb25/
I used he atr45 externally gated from hypergear turbo on my 33 on 98 and made 300kw atw. Great bang for buck. I had all supporting mods 750cc injectors haltech etc if you Have more money to play with gtx3076r gen 1 or 2 is also a great responsive turbo.
Another vote for GTX3071 here.
OP mentioned he was thinking about injectors and AFM etc, so this is a turbo that will make the most out of that. GTX3071 may be not THE_BEST_EVER for outright performance on stock RB25, but it is by far the simplest way to get 99% of the performance anyone is going to ever need given what you've said just now.
I have an Rb25neo with an ATR45 and a mate with a GTX 3071 Gen 2 also on an Rb25neo making roughly around the same power.
Cept my ATR45 is laggy as and you really feel the boost kick in. GTX 3071 Gen 2 is linear and happy days.
High mount, twin scroll, twin gates or one massive single gate and a modern turbo.
Keep the exhaust pressure down and the motor will live.
Food for thought, stock motors will happily crank out ~370kW at the wheels for days if you don't abuse them like a wh0re on the track.
  • Like 2
Atr43g3sat with external gate from hypergear looks to be the goods, best response for that power from what ive read and also for the right price
Surprised by all the gtx3071 votes, lots of people talk about using that turbo but ive not really seen too many that do (dyno graphs that is)
Not sure if there are many results on the GTX 3071 Gen 2 on an RB25 but here is one:
Its a built motor though, but it also has alot of restrictions.
For a internally gated setup the flow of the engine system is strongly dependent on the exhaust, so in a common scenario it will be what ever an 3 inches exhaust can flow, and that is usually up to around 400HP wheels. Anything rated to higher power levels is recommended to work with an external gate unless can run a big straight pipe to ground.
Far as power and response, I recommend our latest Ball bearing ATR43SAT series.  ATR45SAT (Note: ATR45 (3582) and ATR45SAT are very different turbos) is capable of making alot more power if externally gated is in mind.
ATR43G3SAT CBB Power 317rwkws P98 fuel internally gated
ATR43G3SAT CBB Boost 317rwkws P98 fuel internally gated
19 hours ago, Die$eL said:
The car is basically stock.
There's a lot of recommendations made that are going to require a $10k minimum spend to make the car capable of running reliably.  They're not bad ideas, just failing to acknowledge the financials.
Until OP is prepared/able to pony up for all the regular associated upgrades - ECU, cooler, proper exhaust, fuel system, clutch, rubber, brakes, suspension I'd say he's best to stick with a small close to stock sized replacement running low boost eg 10psi and keep motoring until the funds are there.
  • Like 1
Well, if you want to be sensible about it, it doesn't make any sense to buy the "wrong" turbo for his end goal now, just so it won't overrun his injectors and AFM.  Piggie's original recommendation (and mine) implied that he would buy the turbo he wanted AND make sure he had the fuel and management also, although I'll admit that we didn't make that real clear.
Needless to say, the whole exercise is probably best reconsidered.  What the OP really needs is a 2nd hand stock R33 turbo to throw back onto the car until he is actually ready to do the needful.
  • Like 1
But it's SAU, when does anyone listen to sensible recommendations?
My pick would be:
  • Top feed conversion
  • External FPR
  • Wallah bro 460
  • Splitfires
  • Nistune with Feature Pack
  • Continental Flex Sensor
  • EBC of some sort
  • HG G3 Highflow
  • Decent FMIC
  • Decent TBE
  • 1.5/2 way LSD
  • Decent coilovers
  • Traction Rods, Rear camber arms, castor rods, HICAS eliminator
  • Intima SR brake pads all round
Call it a day, 300kW street beast.
My pick would be:
  • External FPR
  • Wallah bro 460
  • Splitfires
  • EBC of some sort
  • HG G3 Highflow
  • Decent FMIC
  • Decent TBE
  • 1.5/2 way LSD
  • Decent coilovers
Pretty much just described my car, almost. Can confirm its an awesome setup on E85.
    • Yeah, my moulds and seals are 32 years old now. I think I will continue to not use a pressure washer on it.
    • I hear the old "I'd never use a pressure washer on my motorbike" BS in the dirtbike community too.  The only people that have had a problem from using a pressure washer on anything are the people that aren't using them properly.  If you hold the wand any more than 45 cms away from pretty much anything (radiators, wiring connectors, paint, etc) you aren't going to cause any damage.  We've had detailers wreck moulds and seals on cars at work before and the only reason why is they held the pressure washer too close and on the one spot for too long.  If you have 5% more brain power than a detailer then you know not to not do that and you'll never have a problem.
    • I'm pretty much healed up post surgery so I spent another almost full day out in the shed re-arranging everything to make room for all of the shit that I've taken off the car.  I need to get everything off the floor and away from the car for when I start making a massive mess stripping off the remaining body deadener and then for the the painting process.  Almost got the shed to a point now where I feel I can actually start working on the car again (clean shed clean mind or something!).  Almost 11 years of accumulated car parts, building supplies, tools, junk, etc have taken a long time to get in some sort of order again!  Most stuff is now boxed up and in the back shed if it's not car related.  Most people would still be horrified walking into my shed but it's significantly better than it was before!   For those that saw my separate post the other day, yeah I ordered one.... This version- I convinced myself to stop being a clown, wake up to yourself and realise it will take you 5 weeks to make one by which stage you're over working on the car again...  Maybe I am getting on top of my "mental ailments" and making smarter choices.... $1450 delivered which will take my miserable half-dutch arse a few days to get over having spent that much!  If I don't have a use for it straight away after my car is off it I might even see if there is a "rental market" for them.  See if anyone wants to hire it for a period of time.  $25 a week or something like that.  I'll worry about that when my car is actually ready to come off it though as that might be a while away!! There's now no excuses now for not ending up with an underside you could eat off! Away for kids sport the next few weekends so hopefully can get the rotisserie assembled ready to go for the car to go straight on it the next available weekend.
    • I always use my Karcher, but it's only a little one that I picked up from Supercheap  The only issue I ever had with a pressure washer was when I was a kid cleaning coaches, they had a hi-po industrial sized petrol jobbie that would strip paint if you got to close I saying this, we have a fairly high power washer at work with a diesel powered heater that sprays water at about 60°c, it works great for removing old wax and road grime on the underbody after some foam cannon action, albeit from a "stand off" distance of a few feet
    • Sorry no - The sandtrap adventure ended the day, happened at the end of the last session. At that time I wasn't hearing any weird noises nor were the brakes shuddering anymore. It was only when watching the videos that I remembered I had these sounds early on!
