Apologies, I know there are probably loads of threads about this. A search brings up a stack of results but nothing that specifically answering my question.
My stock turbo popped on my R33 GTST (I think its series 1.5). There is slight shaft play and the impeller is touching the housing.
Question is, should I recon it and have the ceramic wheel replaced with a metal one or change the turbo?
My end goal is 400-450hp. The plan was to do injectors, MAF etc. before the turbo but i have to change that around now.
If I change the turbo, what are the suggestions for something which will be a straight swop or close to it?
The car is basically stock with just a milteck exhaust.
https://www.sau.com.au/forums/topic/473250-suggested-turbo-on-a-stock-rb25/
I used he atr45 externally gated from hypergear turbo on my 33 on 98 and made 300kw atw. Great bang for buck. I had all supporting mods 750cc injectors haltech etc if you Have more money to play with gtx3076r gen 1 or 2 is also a great responsive turbo.
Another vote for GTX3071 here.
OP mentioned he was thinking about injectors and AFM etc, so this is a turbo that will make the most out of that. GTX3071 may be not THE_BEST_EVER for outright performance on stock RB25, but it is by far the simplest way to get 99% of the performance anyone is going to ever need given what you've said just now.
I have an Rb25neo with an ATR45 and a mate with a GTX 3071 Gen 2 also on an Rb25neo making roughly around the same power.
Cept my ATR45 is laggy as and you really feel the boost kick in. GTX 3071 Gen 2 is linear and happy days.
High mount, twin scroll, twin gates or one massive single gate and a modern turbo.
Keep the exhaust pressure down and the motor will live.
Food for thought, stock motors will happily crank out ~370kW at the wheels for days if you don't abuse them like a wh0re on the track.
  • Like 2
Atr43g3sat with external gate from hypergear looks to be the goods, best response for that power from what ive read and also for the right price
Surprised by all the gtx3071 votes, lots of people talk about using that turbo but ive not really seen too many that do (dyno graphs that is)
Expand
Not sure if there are many results on the GTX 3071 Gen 2 on an RB25 but here is one:
Its a built motor though, but it also has alot of restrictions.
  On 10/01/2018 at 11:14 AM, Rekin said:
Expand
For a internally gated setup the flow of the engine system is strongly dependent on the exhaust, so in a common scenario it will be what ever an 3 inches exhaust can flow, and that is usually up to around 400HP wheels. Anything rated to higher power levels is recommended to work with an external gate unless can run a big straight pipe to ground.
Far as power and response, I recommend our latest Ball bearing ATR43SAT series.  ATR45SAT (Note: ATR45 (3582) and ATR45SAT are very different turbos) is capable of making alot more power if externally gated is in mind.
ATR43G3SAT CBB Power 317rwkws P98 fuel internally gated
ATR43G3SAT CBB Boost 317rwkws P98 fuel internally gated
  On 01/02/2018 at 6:17 AM, Die$eL said:
The car is basically stock.
Expand
There's a lot of recommendations made that are going to require a $10k minimum spend to make the car capable of running reliably.  They're not bad ideas, just failing to acknowledge the financials.
Until OP is prepared/able to pony up for all the regular associated upgrades - ECU, cooler, proper exhaust, fuel system, clutch, rubber, brakes, suspension I'd say he's best to stick with a small close to stock sized replacement running low boost eg 10psi and keep motoring until the funds are there.
  • Like 1
Expand
Well, if you want to be sensible about it, it doesn't make any sense to buy the "wrong" turbo for his end goal now, just so it won't overrun his injectors and AFM.  Piggie's original recommendation (and mine) implied that he would buy the turbo he wanted AND make sure he had the fuel and management also, although I'll admit that we didn't make that real clear.
Needless to say, the whole exercise is probably best reconsidered.  What the OP really needs is a 2nd hand stock R33 turbo to throw back onto the car until he is actually ready to do the needful.
  • Like 1
But it's SAU, when does anyone listen to sensible recommendations?
My pick would be:
  • Top feed conversion
  • External FPR
  • Wallah bro 460
  • Splitfires
  • Nistune with Feature Pack
  • Continental Flex Sensor
  • EBC of some sort
  • HG G3 Highflow
  • Decent FMIC
  • Decent TBE
  • 1.5/2 way LSD
  • Decent coilovers
  • Traction Rods, Rear camber arms, castor rods, HICAS eliminator
  • Intima SR brake pads all round
Call it a day, 300kW street beast.
My pick would be:
  • External FPR
  • Wallah bro 460
  • Splitfires
  • EBC of some sort
  • HG G3 Highflow
  • Decent FMIC
  • Decent TBE
  • 1.5/2 way LSD
  • Decent coilovers
Expand
Pretty much just described my car, almost. Can confirm its an awesome setup on E85.
  On 02/02/2018 at 1:16 AM, Dose Pipe Sutututu said:
I would go GTX3576, a bit more turbine on the rear
Expand
If you go a 3788 you'll have even more headroom... but then again a 4202 would be future proof :P
