Hi Guys, I'm trying to remove the standard dump pipes to install new ones.  I'm stuck at removing the hard water lines and the manifold heat shield. I've attached photos and highlighted what I'm talking about. There are some bolts that are just impossible to get to or maybe it's just because I'm limited to tools.  Any tips would be appreciated - thanks.
You need bent/offset open ended spanners to access the lower ends of these.  Ideally they would be tube/flare spanners rather than open ended, because they are less likely to do damage.  Flare spanners are like a ring spanner with the end cut out.  The cut out is wide enough to pass over the tube and the remaining part of the ring wraps around the hex on the tube nut to still touch all 6 sides, instead of just 2 sides like an open spanner.
The same tools will of course be good for the top tube nuts.
Edited by GTSBoy
Back. Got the water return pipes off, but then I realised that was just the beginning of my problems. Rear turbo manifold has a bolt at the back that is to tight to get to.  Taking a lot longer to install than I thought.  How's everyone's experience with installing dump pipes?
Spoiler
Once all the oil and water lines are off you need to get crafty with a ring spanner to undo the manifolds, then pull turbo and manifold out together.
I can't remember exactly but i think you need to loosen off the flange bolts on the rear turbo so you can weasel the manifold off the studs on the head.
If you find it hard going getting them off you should at least get them rebuilt before you put them back in.
I can pull twins off and put them back on in a day but I’d never pull turbos just to replace dumps
as said you need to unbolt the turbo from the manifold, push the turbo down then unbolt the manifold from the head, pull the manifold out then the turbo
So after a long morning of hard labor turns out that the exhaust doesn't even fit the car... :sad:
So annoyed, was looking forward to it so much.
Below is the connection between the front turbo dump pipe and the front pipe.
Next picture is the position of the front turbo if the dump pipe and front pipe flanges were to be connected.  It's hard to tell from the picture, but the turbo is sitting a lot lower than the standard position and you can see it's angled.
5a7e9d89ed99e_frontturbopositionwithdumppipe.thumb.jpg.0059a0d8fd486e5bb15537001796a53c.jpg
At this stage, I'll probably leave the car in pieces and try to figure something out.
Sorry to hear about the big head f**k dude! But as said above. Ditch the snails mate. Put 1 nice 1 on there and completely change how the car drives from Idle to redline ?
Leave it in pieces till you can afford a manifold and the right size snail to suit your application.
Again as some of the boys have stated and as you've experienced for yourself its A NIGHTMARE so when going to all that effort go for a power/ increased driveability upgrade while you're losing patience, the skin off your knuckles and hours of your life on those nasty ass twins! Swap to 1! Never look back and never deal with your current situation AGAIN! ?
16 hours ago, Count Grantleyish said:
Looks genuine China to me.
Unfortunately, it's genuine Australia.
@Mick_o - Thanks. Oh tell me about it, getting those turbos off was so frustrating. Like @r32-25t said:
I wouldn't do that again for just dumps.
After a brief research session on converting to a single, the bank account wouldn't allow for it. Although I'm actually very interested in a single setup now after reading all the benefits you get compared to twins.
My thinking is to leave the car in pieces and source another set of dumps and fronts. But then that money could also contribute to a single setup :6_smile:
    • Hi all. So one of my major issues at the moment is my rear turbo leaking oil on the exhaust (and the general area). I presumed it was the rock hard super old drain hose, which it was not. So now I am in the midst of removing the rear turbo to get access to the banjo bolt that goes into the turbo oil feed. As one of the previous owners accidentally? tore off the OEM oil feed hardline that reaches behind the turbo, they ran braided lines directly to the turbo, presumably PTFE. Now, regardless if the line has rubber or teflon inside, is it just generally a bad idea to do this? I imagine these lines get quite hot being between the engine, turbo core and exhaust manifold. I suppose it's not too far fetched to think the line may even have melted. I'd love to hear your opinions on this as as the replacement OEM hardline piece is 130 per unit. And cutting open the currently mounted line to see inside will mean I just have to get a replacement either way. So far I am hoping maybe the bolt just loosened or (god forbid) they forgot one of the crush washers.
    • If it's a factory 20de manual probably has the 6 bolt flywheel in which case the det clutches won't work as they're 9 bolt.
    • All RB push clutches are interchangeable. AFAIK, the 4cyl ones are not. Different flywheels. The RB small box is not identical to the 4cyl boxes. Just very similar.
    • Hi. I need a new clutch for my gearbox. It is a factory smallbox behind RB20DE NEO. What options do i have? If iam not mistaken the gearbox should be the same as in R32 GTST and Nissan S14/S15? I found some Xtreme Clutch Stage 1 for S14/S14 (i dont know if you know the brand) (UK) OR...is the clutch same as in the bigbox from RB25DET?   Thank you!
    • Listening to an artist called "the flashbulb". Not bad. Makes some fairly well researched youtube vids in various things.
