Obviously enough, it's different depending on which size pipe it's in.  Choose first.  Millimetres matter here too.  Don't use a curve for a 4" pipe if you don't know what was meant by 4".  Could be 100mm, could be 101.6mm, could be ID, could be OD, could be just about anything.
I'm pretty sure that if you search carefully you'll find that someone has already posted stuff for the R35 sensor for PowerFC.  I don't know where, because I took no notice because I have no time for PowerFC.
If it wasn't for that, I would suggest that you could easily build something from scratch based on the information on it available inside Nistune, by comparing the Nistune Z32 map against the PowerFC Z32 map, and then using that comparison to scale the Nistune R35 map into a PowerFC equivalent.
2 hours ago, Eager said:
Donr see much point changing to nistune and I like the power F.C. hand controller
LOL, the hand controller is useless as donkey shit.
Doesn't show AFR, doesn't show oil temp, doesn't show IAT, doesn't show live fuel trims, doesn't show fuel compensation, doesn't show oil pressure, doesn't show ethanol content, doesn't show what fuel/ignition cuts are active, doesn't show any form of warnings or anything.
50 minutes ago, Eager said:
Ive searched plenty but can’t find anyone saying exactly what they done or what’s needed
Millennial children. I hope my kids aren't that shit
Here you go Mr I've Searched Plenty lol
  • Like 1
  • Haha 1
Err, wouldn't you want a "hand controller" to show you those things? WTF APEXi?
Belongs wherever ya like, it’s still the most used jap tuning solution I would say and most recognised around the world. It will do my job, I’ve installed 3 link’s in previous toys and super ecu but for day to driving there wasn’t a lot of difference to my previous power F.C. tuner cars
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
    • Hope the cans went down well at least
    • 255 can't go wrong with the price.
    • When I was replacing my pump due to being stranded in the wrong state, I went with the Deatschwerks 320lph kit. It is a direct plug in to the stock wires, harness, everything. It comes with a plug... but you can plug the OEM plug directly into this thing. https://justjap.com/products/deatschwerks-dw300-fuel-pump-nissan-s13-silvia-r32-r33-r34-skyline-c34-stagea?currency=AUD Downside: Won't actually flow that much on boost if you want to push it on E85, but it's comparable to the 040/255 etc. Little more actually.
