57 minutes ago, Sovereign337 said:
If you haven't previously held a license, what do you guys recommend? AASA or L2S?
Shane!!!! L2S will be a little dearer, but it'll cover you for more events. On top of that, CAMS licences are accpeted by AASA, but its not necessarily the same for AASA licences at CAMS event.... @crashdown will need to confirm....
  • Like 1
Ladies and Gentlemen,
As part of each member's entry to SAU NSW's GP Track Day, Heasman Steering will be hosting a tech night on corner-weighing, shock rate design, and suspension set up for the track.
There are limited spots available, with 10 dedicated spots for members, in particular those who've entered GP. We'll be posting up a separate thread on the tech night to open it up to all members, but for now, for those who've entered GP, please let us know if you're keen on the tech night also.
Final details will be shared in the members thread in the coming days, but it will be held on one of the thursdays leading up to the track day.
First in, first served!
  • Like 1
I would be interested in attending
So to be clear, does that mean that the 1 day CAMS license is no longer available?
Got a couple of mates who are keen for the trackday but not so keen at having to buy the yearly license from CAMS.
I'll need to find that out for you, from the club executive in charge of that department. I will follow that up and get back to you with a reply.
We can supply a day licence.
Could you please let us know how many you would require (even if it is a max amount) before this Friday 20/4.
This is because we need to ensure we have enough available.
Thanks for following up.
Max would be 5.
I've got 3 definite and 2 tentatives
Max would be 5.
I will have 5 put to the side.
When they pay for their entry, let me know and I'll then allocate a day licence to each name. That way the sign on desk, will know on the day.
Greetings guys, not sure what the go is as its been a millenium since I've set foot near a track in a car.
Can someone please give me No.26 and link this forum name to my member number as I thought it would have been deleted soI left it off lol.
Much thanks Easto
  • Like 1
    • Sadly I can confirm if you are actually seeking to drift, you will quite easily spin up one wheel. Even if you're going in a straight line. I am not entirely sure of the metrics/terminology here but there's only a certain amount that the helical will actually spin both wheels. I've seen it on video with my own car where two lines of smoke switch over to just one after you really get in to it. Unlike with a clutch diff where you can keep your foot planted until the car regains grip, in my experience with the helical you want to be utilizing traction control allowing LIMITED slip or lifting (partially) when you start to spin up both tyres with a Nissan helical. Which makes them pretty sub optimal for drifting duty. That said... this is probably a helical on numbers alone. Just put the Kazz in
    • Let's just fix the problem by f**king the rest of the gearbox.
    • Unlikely, as per Greg's post. This is not helical diff behaviour unless one wheel is up off the ground. Shimming what? You don't "shim" a mechanical LSD. Probably not in the sense that you have heard of people "shimming" a diff. And the process that Nissan f**kwits call "shimming" a diff involves super-preloading a VLSD cartridge against the side of the diff to create a friction/wear point (in a place that it wasn't supposed to have one) to make the sloppy, useless, viscous diff into a hybrid viscous/mech abortion. In case it isn't clear, I consider the process to be stupid. Nike.
    • How much does the shifter move when the car is in gear with the engine off? If it is more than about 1cm you need to replace your shifter bush. Your shifts will just get crunchier, not faster, with a short shifter unless you also rebuild the whole box
    • I should video mine, will prob do it tomorrow    Between 1st and 3rd, you could fit another two gears. That is how loose and wobbly it is   horrible:(
